problem with postGIS and WMS capabilities if wms_extent not
defined
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Fri Nov 19 16:10:23 EST 2004
Bart van den Eijnden wrote:
> Hi list,
> I have a PostGIS layer in my MAP file and I am using the 4.4 beta2 windows
> binary from maptools.org. I am on Windows 2000 server.
> If I don't define a WMS_EXTENT in the METADATA section of my LAYER, I get
> a crash of the WMS capabilities (only 4 Kb of normally 5 Kb is sent). If I
> do define the WMS_EXTENT everything works fine.
Did this use to work with 4.2? Some work was dont in this area after
beta2, but I'm not aware of this issue. Perhaps you could also try with
the latest source from CVS if you can.
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
