WMS Server and Proxy with v4.4
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Mon Nov 22 12:36:10 EST 2004
Shanton, James A wrote:
> Is it possible to pass proxy settings to WMS layers in version 4.4 of
> mapserver? This is listed in bugzilla bug 571
> (http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=571) with a target
> release of 4.4, but the bug is still open. I am having trouble using
> the http_proxy environment variable to do this, and was wondering if the
> new build would solve my problem.
Bug 571 has not been and won't be addressed in 4.4 (too late). The
environment variables would be the only workaround for now. I've never
tried using them myself so I can't help with that, but usually the CURL
library is very reliable and well documented, so if you find the docs
and follow them closely you should be able to get them to work.
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
