WMS Request Question
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Nov 23 11:41:14 EST 2004
Hi Scott,
Mapserver has been changed recently so that it conforms to the WMS spec.
This part of the documentation is a relic from the days that it was more
leniant.
Maybe we need to open up a documentation bug for this, or maybe it is
already on the list or in bugzilla (Jeff?).
Best regards,
Bart
On Tue, 23 Nov 2004 11:38:50 -0500, Tweedy, Scott <sctweedy at NRCAN.GC.CA>
wrote:
> Thanks for your answer yesterday Bart, but here's the statement in the
> WMS
> Server HOWTO document
> (http://mapserver.gis.umn.edu/doc/wms-server-howto.html) that had me
> "confused"
> Option A: Use Only Parameters Required by MapServer
> Simply adding
> "VERSION=1.1.1&REQUEST=GetMap&LAYERS=yourlayername1,yourlayername2" to
> your
> server's URL should generate a map with the default map size and all the
> layers with STATUS ON or DEFAULT displayed, e.g.
> The statement is in the "Test With a GetMap Request" section. It seems
> to
> state that if STATUS is ON or DEFAULT the layer would be displayed,
> therefore conversely saying that if STATUS is OFF it won't.
> I konw the WMS call seems to ignore the STATUS of a layer, but this
> statement seems to suggest otherwise, which is correct (or better yet
> which
> should be correct)?
> Thanks in advance again,
> st
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
> Behalf Of Tweedy, Scott
> Sent: Monday, November 22, 2004 2:23 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] WMS Request Question
> I have a question about a WMS requestion respecting the STATUS parameter
> within a map file.
> I have a Mapfile that has numerous layers in it, some are initially
> turned
> on, some off using the STATUS object. The Mapfile works fine if I call
> it
> through a webpage, but if I call it using a WMS request this STATUS
> object
> seems to get ignored and all layers are turned on. Is this normal
> behaviour
> for Mapserver v. 4.3? If so is there any way around it?
> st
> Scott Tweedy
> Geoscience Database Analyst - Analyste de base des données
> géoscientifiques
> ESS Geoinformatics Division - Division SST Géoinformatique
> Earth Sciences Sector - Secteur des sciences de la terre
> Natural Resources Canada - Ressources naturelles Canada
> 580-615 Booth Street - 580-615 rue Booth
> Ottawa, ON Canada K1A 0E9
> tel. (613) 947-0665 - tél. (613) 947-0665
> fax (613) 995-2520 - télc. (613) 995-2520
> Email sctweedy at nrcan.gc.ca - Courriel sctweedy at nrcan.gc.ca
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
