Things are comming along but .... please look at this mapfile dump
Joseph Norris
sirronj at PACBELL.NET
Mon Nov 29 14:12:40 EST 2004
Hello again,
I am now on the quest to add points to my map of zips in California. I have
the following map file but the points are not showing up in the layer. If
you can see anything that I need to change - please let me know. I have
found that it is easier to work from a dump of the mapfile - make
adjustments then return to my perl script and make sure that these
adjustments happen.
Thanks to all.
MAP
EXTENT 5706290.827754 -192053.2 9127890.404246 3226086.749
TEMPLATEPATTERN "map"
IMAGECOLOR 255 255 255
IMAGETYPE gif
SHAPEPATH
"/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/teacher/tdata
SIZE 600 600
STATUS ON
UNITS DD
NAME "calmap"
OUTPUTFORMAT
NAME gif
MIMETYPE image/gif
DRIVER GD/GIF
EXTENSION gif
IMAGEMODE PC256
TRANSPARENT FALSE
END
SYMBOL
NAME "circle"
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
SYMBOL
NAME "plus"
TYPE VECTOR
POINTS
0.5 0
0.5 1
-99 -99
0 0.5
1 0.5
END
END
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION CC
END
POSITION LL
STATUS EMBED
END
QUERYMAP
COLOR 255 255 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
SCALEBAR
COLOR 0 0 0
INTERVALS 4
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
SIZE 200 3
STATUS OFF
STYLE 0
UNITS MILES
END
WEB
IMAGEPATH ""
IMAGEURL ""
QUERYFORMAT text/html
END
LAYER
NAME "points"
SIZEUNITS PIXELS
STATUS ON
TEMPLATE "bogus.html"
TOLERANCE 10
TOLERANCEUNITS PIXELS
TYPE POINT
UNITS METERS
CLASS
NAME "buoy"
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 2
COLOR 255 102 102
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS FALSE
POSITION AUTO
END
STYLE
COLOR 255 102 102
MAXSIZE 100
MINSIZE 1
OUTLINECOLOR 255 255 255
SIZE 8
SYMBOL "circle"
END
END
FEATURE
POINTS
-121.507 38.5263
END
TEXT "Mary Lyn Kagan"
END
FEATURE
POINTS
-122.451 37.7752
END
TEXT "Greg D'Amico"
END
FEATURE
POINTS
-119.646 36.3426
END
TEXT "Leslie Steffen"
END
FEATURE
POINTS
-122.54 38.0065
END
TEXT "john antico"
END
FEATURE
POINTS
-116.976 32.7712
END
TEXT "SWANSONG BRAHMAN"
END
END
LAYER
CLASSITEM "zcta"
DATA "cal_zp_st"
NAME "calzip"
SIZEUNITS PIXELS
STATUS DEFAULT
TOLERANCE 0
TYPE POLYGON
UNITS METERS
CLASS
NAME "Zip Boundries"
EXPRESSION /./
STYLE
MAXSIZE 100
MINSIZE 1
OUTLINECOLOR 204 204 204
SIZE 1
SYMBOL 0
END
END
END
END
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
