Things are comming along but .... please look at this mapfile
dump
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Nov 29 14:25:47 EST 2004
Joseph,
I seem to remember a bug a while back about symbols defined in the
mapfile not always working that the you needed to move them in to a
separate symbol file that you reference in the mapfile.
Also, I believe that "symbol 0" is a predefined mapserver symbol that is
the same as circle.
Somebody please correct this if the above assumptions are wrong.
-Steve W.
Joseph Norris wrote:
> Hello again,
> I am now on the quest to add points to my map of zips in California. I have
> the following map file but the points are not showing up in the layer. If
> you can see anything that I need to change - please let me know. I have
> found that it is easier to work from a dump of the mapfile - make
> adjustments then return to my perl script and make sure that these
> adjustments happen.
> Thanks to all.
> MAP
> EXTENT 5706290.827754 -192053.2 9127890.404246 3226086.749
> TEMPLATEPATTERN "map"
> IMAGECOLOR 255 255 255
> IMAGETYPE gif
> SHAPEPATH
> "/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/teacher/tdata
> SIZE 600 600
> STATUS ON
> UNITS DD
> NAME "calmap"
> OUTPUTFORMAT
> NAME gif
> MIMETYPE image/gif
> DRIVER GD/GIF
> EXTENSION gif
> IMAGEMODE PC256
> TRANSPARENT FALSE
> END
> SYMBOL
> NAME "circle"
> TYPE ELLIPSE
> FILLED TRUE
> POINTS
> 1 1
> END
> END
> SYMBOL
> NAME "plus"
> TYPE VECTOR
> POINTS
> 0.5 0
> 0.5 1
> -99 -99
> 0 0.5
> 1 0.5
> END
> END
> LEGEND
> KEYSIZE 20 10
> KEYSPACING 5 5
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 0
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> POSITION CC
> END
> POSITION LL
> STATUS EMBED
> END
> QUERYMAP
> COLOR 255 255 0
> SIZE -1 -1
> STATUS OFF
> STYLE HILITE
> END
> SCALEBAR
> COLOR 0 0 0
> INTERVALS 4
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 0
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> END
> POSITION LL
> SIZE 200 3
> STATUS OFF
> STYLE 0
> UNITS MILES
> END
> WEB
> IMAGEPATH ""
> IMAGEURL ""
> QUERYFORMAT text/html
> END
> LAYER
> NAME "points"
> SIZEUNITS PIXELS
> STATUS ON
> TEMPLATE "bogus.html"
> TOLERANCE 10
> TOLERANCEUNITS PIXELS
> TYPE POINT
> UNITS METERS
> CLASS
> NAME "buoy"
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 2
> COLOR 255 102 102
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS FALSE
> POSITION AUTO
> END
> STYLE
> COLOR 255 102 102
> MAXSIZE 100
> MINSIZE 1
> OUTLINECOLOR 255 255 255
> SIZE 8
> SYMBOL "circle"
> END
> END
> FEATURE
> POINTS
> -121.507 38.5263
> END
> TEXT "Mary Lyn Kagan"
> END
> FEATURE
> POINTS
> -122.451 37.7752
> END
> TEXT "Greg D'Amico"
> END
> FEATURE
> POINTS
> -119.646 36.3426
> END
> TEXT "Leslie Steffen"
> END
> FEATURE
> POINTS
> -122.54 38.0065
> END
> TEXT "john antico"
> END
> FEATURE
> POINTS
> -116.976 32.7712
> END
> TEXT "SWANSONG BRAHMAN"
> END
> END
> LAYER
> CLASSITEM "zcta"
> DATA "cal_zp_st"
> NAME "calzip"
> SIZEUNITS PIXELS
> STATUS DEFAULT
> TOLERANCE 0
> TYPE POLYGON
> UNITS METERS
> CLASS
> NAME "Zip Boundries"
> EXPRESSION /./
> STYLE
> MAXSIZE 100
> MINSIZE 1
> OUTLINECOLOR 204 204 204
> SIZE 1
> SYMBOL 0
> END
> END
> END
> END
> #Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
> $_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
> 68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
