Things are comming along but .... please look at this mapfile
dump
David Fawcett
David.Fawcett at STATE.MN.US
Mon Nov 29 14:26:05 EST 2004
Joseph,
A few things that I noticed that are probably related to your problem:
It looks like your EXTENT is in meters suggesting a UTM projection.
Your UNITS specify DD, suggesting that your data is in Lat Long.
It also looks like you are creating your new points using Lat Long.
If all of your data is truly unprojected (lat/long), then all you
should need to do is change your extent to the appropriate boundaries
for your data in lat/long.
My guess is that you got your EXTENT from your Zip Code shapefile,
which suggests that it is projected to something like UTM. If this is
the case, you will have to add a PROJECTION block for the map and
PROJECTION information for each layer in your map file.
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> Joseph Norris <sirronj at PACBELL.NET> 11/29/2004 1:12:40 PM >>>
Hello again,
I am now on the quest to add points to my map of zips in California. I
have
the following map file but the points are not showing up in the layer.
If
you can see anything that I need to change - please let me know. I
have
found that it is easier to work from a dump of the mapfile - make
adjustments then return to my perl script and make sure that these
adjustments happen.
Thanks to all.
MAP
EXTENT 5706290.827754 -192053.2 9127890.404246 3226086.749
TEMPLATEPATTERN "map"
IMAGECOLOR 255 255 255
IMAGETYPE gif
SHAPEPATH
"/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/teacher/tdata
SIZE 600 600
STATUS ON
UNITS DD
NAME "calmap"
OUTPUTFORMAT
NAME gif
MIMETYPE image/gif
DRIVER GD/GIF
EXTENSION gif
IMAGEMODE PC256
TRANSPARENT FALSE
END
SYMBOL
NAME "circle"
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
SYMBOL
NAME "plus"
TYPE VECTOR
POINTS
0.5 0
0.5 1
-99 -99
0 0.5
1 0.5
END
END
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION CC
END
POSITION LL
STATUS EMBED
END
QUERYMAP
COLOR 255 255 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
SCALEBAR
COLOR 0 0 0
INTERVALS 4
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
SIZE 200 3
STATUS OFF
STYLE 0
UNITS MILES
END
WEB
IMAGEPATH ""
IMAGEURL ""
QUERYFORMAT text/html
END
LAYER
NAME "points"
SIZEUNITS PIXELS
STATUS ON
TEMPLATE "bogus.html"
TOLERANCE 10
TOLERANCEUNITS PIXELS
TYPE POINT
UNITS METERS
CLASS
NAME "buoy"
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 2
COLOR 255 102 102
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS FALSE
POSITION AUTO
END
STYLE
COLOR 255 102 102
MAXSIZE 100
MINSIZE 1
OUTLINECOLOR 255 255 255
SIZE 8
SYMBOL "circle"
END
END
FEATURE
POINTS
-121.507 38.5263
END
TEXT "Mary Lyn Kagan"
END
FEATURE
POINTS
-122.451 37.7752
END
TEXT "Greg D'Amico"
END
FEATURE
POINTS
-119.646 36.3426
END
TEXT "Leslie Steffen"
END
FEATURE
POINTS
-122.54 38.0065
END
TEXT "john antico"
END
FEATURE
POINTS
-116.976 32.7712
END
TEXT "SWANSONG BRAHMAN"
END
END
LAYER
CLASSITEM "zcta"
DATA "cal_zp_st"
NAME "calzip"
SIZEUNITS PIXELS
STATUS DEFAULT
TOLERANCE 0
TYPE POLYGON
UNITS METERS
CLASS
NAME "Zip Boundries"
EXPRESSION /./
STYLE
MAXSIZE 100
MINSIZE 1
OUTLINECOLOR 204 204 204
SIZE 1
SYMBOL 0
END
END
END
END
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print
@c=map chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
