Help with displaying a single RASTER image
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Fri Oct 1 15:16:25 EDT 2004
Make sure the units/projection of your geotiff are the same as your
EXTENT.
Gdalinfo is your friend....
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Bob Bruce
Sent: Friday, October 01, 2004 1:04 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Help with displaying a single RASTER
I am reviewing the tutorial and re-learning the MapServer by looking
over work that I had done previously on another computer and converting
examples that I had done with my own data (and that previously worked)
to the new paths on this computer. Now I am finding that I cannot get
the server to display a single GeoTIFF image under some vector data. I
can see the vector data but the raster image won't draw for some reason.
I hope that someone out there has some suggestion as to why the raster
isn't appearing. I have checked my path to the raster data and it is
correct. I have tried settings with processing the COLOR_MATCH_THRESHOLD
and it didn't work. I even tried turning off INTERLACE in the map image
and it didn't work.
The strange thing is that when I jump ahead to an example that I had
done with image tiles, this works and displays the raster tiles. But I
can't seem to get it to work with a single image. I also can't get the
raster in the standard tutorial35 to display.
Does anyone out there have an answer to my problem?
My MapServer configuration is:
C:\Apache\htdocs\MapserverTutorial>..\CGI-BIN\MAPSERV.EXE -v MapServer
version 4.2.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
My map file is:
NAME T12R02E_s2ex2
EXTENT 620000 5535000 631000 5547350
SIZE 400 400
# SHAPEPATH "C:/Apache/htdocs/MapserverTutorial/TilesWWinnipeg/t12r02e"
SHAPEPATH "C:/Apache/htdocs/MapserverTutorial/TilesWWinnipeg"
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
IMAGETYPE png
LAYER # Single ortho image display
NAME "6205531GeoTIFF"
DATA "t12r02e/orthodata/6205531G.tiff"
# STATUS DEFAULT
TYPE RASTER
STATUS ON
PROCESSING "SCALE=AUTO"
# OFFSITE 0 0 0
PROCESSING "COLOR_MATCH_THRESHOLD=8"
END
LAYER # DLS Polys
NAME "DLSPolys"
DATA t12r02e/t12r02ev03_DLSPolygons
STATUS DEFAULT
TYPE POLYGON
CLASSITEM "PART"
CLASS # Whole DLS Parcel
STATUS OFF
NAME "WHOLE DLSPOLY"
EXPRESSION ""
COLOR 255 202 149
OUTLINECOLOR 0 0 0
END # end of Whole DLS Parcel class object
CLASS # Part DLS Parcel
NAME "PART DLSPOLY"
EXPRESSION "PT"
COLOR 255 164 72
OUTLINECOLOR 0 0 0
END # end of Part DLS Parcel class object
END # end of layer object
LAYER # Plan Parcel Layer
NAME "Plan Parcels"
DATA t12r02e/t12r02ev03_LotPolygons
STATUS DEFAULT
TYPE POLYGON
CLASSITEM "PART"
CLASS # Whole Plan Parcels
NAME "Whole Plan Parcels"
EXPRESSION ""
COLOR 212 178 176
OUTLINECOLOR 0 0 0
END # end of Whole Plan Parcels class
CLASS # Part Plan Parcels
NAME "Part Plan Parcels"
EXPRESSION "PT"
COLOR 170 103 100
OUTLINECOLOR 0 0 0
END # end of water features layer
END # end of map file
and the line in my HTML file that runs the MapServer is:
<img border="1"
src="/cgi-bin/mapserv.exe?map=C:/Apache/htdocs/MapserverTutorial/TilesWW
innipeg/s2/t12r02e-ex2.map&mode=map">
thanks in advance for your help.
Bob Bruce
