showing 2 landsat utm geotiff
Jan Hartmann
j.l.h.hartmann at UVA.NL
Sat Oct 2 10:01:22 EDT 2004
Joerg,
You have two layers in different projections. This means that you have
to define a projection block in each layer *plus* an output projection
in the "map" part of the mapfile. I'm not sure what that last one should
be; probably some sort of global German epsg projection.
And then: both layers have to be STATUS DEFAULT!
Jan
joerg p wrote:
> hello,
> I have landsat utm geotiffs zone 32 and 33 and would like to show them
> both. I can show only either 32 or 33... Whats wrong?
> joerg
> mapfile:
> MAP
> IMAGETYPE jpeg
> EXTENT 203700.00 5700000.00 800000.00 6000000.00
> UNITS METERS
> SIZE 800 400
> IMAGECOLOR 112 135 148
> DEBUG ON
> WEB
> LOG "C:\ms_tmp\logfile.txt"
> IMAGEPATH "C:\ms_tmp\"
> IMAGEURL "/ms_tmp/"
> TEMPLATE "northTempl_2.html"
> END
> LAYER
> NAME landsathamburgz32
> STATUS DEFAULT
> DATA "data/raster/landsat/z32_etmMosaic_halftone.tif"
> #OFFSITE 0 0 0
> TYPE RASTER
> DEBUG ON
> END
> LAYER
> NAME landsatberlinz33
> STATUS ON
> DATA "data/raster/landsat/z33_etmMosaic_halftone.tif"
> #OFFSITE 0 0 0
> TYPE RASTER
> DEBUG ON
> END
> END # Map File
