showing 2 landsat utm geotiff
joerg p
superbla3000 at GMX.NET
Sat Oct 2 10:29:26 EDT 2004
ok, I got it. This means I have to tell mapserver to project z32 as
zone=32 and z33 as zone=33. The map I projected as zone=32, so now it
takes a long time to reproject z33.
So this is why using utm for a larger area isn't good..hhmmm... what
should I use instead? LatLong?
Joerg
Jan Hartmann wrote:
> Joerg,
> You have two layers in different projections. This means that you have
> to define a projection block in each layer *plus* an output projection
> in the "map" part of the mapfile. I'm not sure what that last one should
> be; probably some sort of global German epsg projection.
> And then: both layers have to be STATUS DEFAULT!
> Jan
> joerg p wrote:
>> hello,
>> I have landsat utm geotiffs zone 32 and 33 and would like to show them
>> both. I can show only either 32 or 33... Whats wrong?
>> joerg
>> mapfile:
>> MAP
>> IMAGETYPE jpeg
>> EXTENT 203700.00 5700000.00 800000.00 6000000.00
>> UNITS METERS
>> SIZE 800 400
>> IMAGECOLOR 112 135 148
>> DEBUG ON
>> WEB
>> LOG "C:\ms_tmp\logfile.txt"
>> IMAGEPATH "C:\ms_tmp\"
>> IMAGEURL "/ms_tmp/"
>> TEMPLATE "northTempl_2.html"
>> END
>> LAYER
>> NAME landsathamburgz32
>> STATUS DEFAULT
>> DATA "data/raster/landsat/z32_etmMosaic_halftone.tif"
>> #OFFSITE 0 0 0
>> TYPE RASTER
>> DEBUG ON
>> END
>> LAYER
>> NAME landsatberlinz33
>> STATUS ON
>> DATA "data/raster/landsat/z33_etmMosaic_halftone.tif"
>> #OFFSITE 0 0 0
>> TYPE RASTER
>> DEBUG ON
>> END
>> END # Map File
