WKT projection definition string
Frank Warmerdam
warmerdam at POBOX.COM
Mon Oct 4 10:50:27 EDT 2004
Nicol Hermann wrote:
> Hi List,
> Does anybody have a OGC WKT projection definition string which is valid
> to use it with the method setWKTProjection() of PHP mapscript?
> The one i found
> PROJCS[ NAD_1983_UTM_Zone_10N ,
> GEOGCS[ GCS_North_American_1983 ,
> DATUM[ D_North_American_1983 ,
> SPHEROID[ GRS_1980 ,6378137,298.257222101]],
> PRIMEM[ Greenwich ,0],
> UNIT[ Degree ,0.0174532925199433]],
> PROJECTION[ Transverse_Mercator ],
> PARAMETER[ False_Easting ,500000.0],
> PARAMETER[ False_Northing ,0.0],
> PARAMETER[ Central_Meridian ,-123.0],
> PARAMETER[ Scale_Factor ,0.9996],
> PARAMETER[ Latitude_of_Origin ,0.0],
> UNIT[ Meter ,1.0]]
> in the Simple Features specification did not work. The method
> $layer -> getProjection()
> returns false.
Nicol,
Hmm, that worked for me going through a slightly different way to the same
low level code. The massaged form of this definition it gave base was as
follows. Try that.
PROJCS["NAD_1983_UTM_Zone_10N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-123.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_of_Origin",0.0],UNIT["Meter",1.0]]
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
