gdalindex question
Dylan Keon
keon at NACSE.ORG
Mon Oct 4 16:50:32 EDT 2004
Hi Dylan :-)
After upgrading to 4.2.x or so, I found I had to use absolute paths for
tileindexes. That is, SHAPEPATH wouldn't work with my TILEINDEX
declaration. So, try:
TILEINDEX "/full/path/to/imagery/doqq/tiled/doqq_index.shp"
and see if that makes a difference. Also, are you sure it's TILEITEM
"Location" instead of "location"? It may be case sensitive, I can't
remember.
--Dylan
On 10/04/2004 01:45 PM, Dylan Beaudette wrote:
> Ed-
> Thanks for the quick reply!
> The mapserver output looks a litte funny because I am displaying the tile
> index as a polygon layer, so that I know that it actually exists, and is
> projected corectly. The labels do look like strange file names, but they are
> indeed correct...
> when i attempt to access the rasters individually:
> DATA "imagery/doqq/tiled/o38122f1nw.tif.temp.tiff"
> ...it works fine:
> http://169.237.35.250/~dylan/temp/tile_index_with_1_raster.jpg
> ...but the rasters are not loaded via the TILEINDEX method.
> here is the updated layer definition (thanks for the OFFSITE idea!!)
> ----------------snip------------------
> LAYER
> NAME "DOQQ_index"
> TYPE RASTER
> TILEINDEX "imagery/doqq/tiled/doqq_index.shp"
> TILEITEM "Location"
> #DATA "imagery/doqq/tiled/o38122f1nw.tif.temp.tiff"
> STATUS DEFAULT
> #ignore black pixels (treat as transparent)
> OFFSITE 0 0 0
> #render the rest of the pixel values!
> CLASS
> NAME "DOQQ"
> END
> END
> ...still no success with the rasters this way...
> any ideas?
> thanks again!
> Dylan
> On Monday 04 October 2004 11:37 am, Ed McNierney wrote:
>>Dylan -
>>Thanks for asking a well-documented question!
>>Your MapServer output looks like you're using the tile index layer as a
>>POLYGON layer, and doesn't seem to match up with the map file fragment you
>>post (i.e. there's no TYPE POLYGON layer with labels there). The filenames
>>that are appearing as labels look a little funny - are you sure those are
>>the correct filenames?
>>Also, you're causing all black pixels to be displayed as white, which won't
>>"remove" them. You may want to use the OFFSITE statement to cause black
>>pixels to be transparent, letting overlapped data show through.
>> - Ed
>>Ed McNierney
>>President and Chief Mapmaker
>>TopoZone.com
>>At 02:18 PM 10/4/2004, Dylan Beaudette wrote:
>>>Greetings!
>>>I have a pile of DOQQ images that i would like to use with my map, and
>>>wanted to use gdalindex to setup an efficient way for these images to be
>>>loaded.
>>>note that everything is in the same projection.
>>>after running:
>>>gdaltindex doqq_index.shp *.tiff
>>>i am left with a shapfile with entries for all of the images.... seems ok.
>>>...looking at the output in QGIS:
>>>http://169.237.35.250/~dylan/temp/gdalindex_problems.jpg
>>>...all seems fine (except for a few mssing images)
>>>however mapserver is not rendering the tiff files based on the index:
>>>http://169.237.35.250/~dylan/temp/tile_index.png
>>>here is my layer defs in my map file:
>>>----------------------------snip----------------------------
>>>LAYER
>>> NAME "DOQQ_index"
>>> TYPE RASTER
>>> TILEITEM "Location"
>>> STATUS DEFAULT
>>> #remove the black (no_data) pixels!
>>> CLASSITEM "[pixel]"
>>> CLASS
>>> EXPRESSION ([pixel] == 0 )
>>> COLOR 255 255 255
>>> END
>>> CLASS
>>> NAME "DOQQ"
>>> END
>>>END
>>>any ideas>?
>>>thanks in advance!!
>>>Dylan Beaudette
>>>Soil Science Grad Group
>>>University of California at Davis
Dylan Keon - GIS Coordinator
Northwest Alliance for Computational Science and Engineering
Oregon State University
Corvallis, OR 97331
keon at nacse.org voice: 541-737-6608 fax: 541-737-6609
http://gis.nacse.org
