gdalindex question
Dylan Beaudette
dylan at IICI.NO-IP.ORG
Mon Oct 4 16:45:27 EDT 2004
Ed-
Thanks for the quick reply!
The mapserver output looks a litte funny because I am displaying the tile
index as a polygon layer, so that I know that it actually exists, and is
projected corectly. The labels do look like strange file names, but they are
indeed correct...
when i attempt to access the rasters individually:
DATA "imagery/doqq/tiled/o38122f1nw.tif.temp.tiff"
...it works fine:
http://169.237.35.250/~dylan/temp/tile_index_with_1_raster.jpg
...but the rasters are not loaded via the TILEINDEX method.
here is the updated layer definition (thanks for the OFFSITE idea!!)
----------------snip------------------
LAYER
NAME "DOQQ_index"
TYPE RASTER
TILEINDEX "imagery/doqq/tiled/doqq_index.shp"
TILEITEM "Location"
#DATA "imagery/doqq/tiled/o38122f1nw.tif.temp.tiff"
STATUS DEFAULT
#ignore black pixels (treat as transparent)
OFFSITE 0 0 0
#render the rest of the pixel values!
CLASS
NAME "DOQQ"
END
END
...still no success with the rasters this way...
any ideas?
thanks again!
Dylan
On Monday 04 October 2004 11:37 am, Ed McNierney wrote:
> Dylan -
> Thanks for asking a well-documented question!
> Your MapServer output looks like you're using the tile index layer as a
> POLYGON layer, and doesn't seem to match up with the map file fragment you
> post (i.e. there's no TYPE POLYGON layer with labels there). The filenames
> that are appearing as labels look a little funny - are you sure those are
> the correct filenames?
> Also, you're causing all black pixels to be displayed as white, which won't
> "remove" them. You may want to use the OFFSITE statement to cause black
> pixels to be transparent, letting overlapped data show through.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com
> At 02:18 PM 10/4/2004, Dylan Beaudette wrote:
> >Greetings!
> >I have a pile of DOQQ images that i would like to use with my map, and
> > wanted to use gdalindex to setup an efficient way for these images to be
> > loaded.
> >note that everything is in the same projection.
> >after running:
> >gdaltindex doqq_index.shp *.tiff
> >i am left with a shapfile with entries for all of the images.... seems ok.
> >...looking at the output in QGIS:
> >http://169.237.35.250/~dylan/temp/gdalindex_problems.jpg
> >...all seems fine (except for a few mssing images)
> >however mapserver is not rendering the tiff files based on the index:
> >http://169.237.35.250/~dylan/temp/tile_index.png
> >here is my layer defs in my map file:
> >----------------------------snip----------------------------
> >LAYER
> > NAME "DOQQ_index"
> > TYPE RASTER
> > TILEITEM "Location"
> > STATUS DEFAULT
> > #remove the black (no_data) pixels!
> > CLASSITEM "[pixel]"
> > CLASS
> > EXPRESSION ([pixel] == 0 )
> > COLOR 255 255 255
> > END
> > CLASS
> > NAME "DOQQ"
> > END
> >END
> >any ideas>?
> >thanks in advance!!
> >Dylan Beaudette
> >Soil Science Grad Group
> >University of California at Davis
