[UMN_MAPSERVER-USERS] Trouble with queryby...
Lowell Filak
lfilak at MEDINACO.ORG
Wed Oct 6 12:20:09 EDT 2004
The following message was sent by Frank Broniewski
<Frank.Broniewski at MNHA.ETAT.LU> on Wed, 6 Oct 2004 14:21:47 +0200.
> Hello
> Yes of course ;-)
> Template "dasistegal.html"
> It is a dummy template
> LAYER
> Name "Points"
> Data epc/points
> Status Off
> Type Point
> Tolerance 5
> Group "Compléments"
> Metadata
> access "2"
> database "tbl_point"
> End
> Class
> Name "Points"
> # Template "dasistegal.html"
> Style
> symbol "circle"
> color 0 255 0
> size 2
> End
> End
> END
> This is the complete layer definition.
> Frank Broniewski
> Musée National d'Histoire et d'Art
> Section Préhistoire / Projet EPC
> Tél: +352 260 281-21
> 241, Rue de Luxembourg
> L-8077 Bertrange
> -----Message d'origine-----
> De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] >
De la
> part de Lowell Filak
> Envoyé : mercredi 6 octobre 2004 13:16
> À : MAPSERVER-USERS at LISTS.UMN.EDU
> Objet : Re: [UMN_MAPSERVER-USERS] Trouble with queryby...
> Frank,
> Do you have a "template" set for the layer?
> Lowell
Frank,
I it could be a few things then.
As others already suggested, are you certain the layer is turned on
before the query?
It sounds like you have verified that the query coordinates being used
are in map coordinates vs pixel coordinates.?
Could it be a projection issue or is all the data in the same projection?
Lowell
