Creating SVG from Shapefile, Oracle Spatial, ArcSDE
Ivano Picco
ivano.picco at AQUPI.TK
Wed Oct 6 08:56:32 EDT 2004
Hi all,
I'm a newbie user, I try to find the answer to my problems in the ML
archives, but i can't find anything for these questions:
I trying to build a new WebGis application that can be used instead ArcIMS
based ones to perform a reliable, robust and fast map rendering. I'm looking
to MapServer. Since 1 month I spent my time to learn it and test it in some
situations, such as rendering png, export WMS map and feature, rendering SVG
map.
In my test I see the best performance achieved by using shapefile, but I
have to use layer from different sources, also in the same time, like ArcSDE
or Oracle Spatial.
On rendering pngs, my benchmark from a shapefile (260 Mbyte, 198401
features) hits a 7,62 seconds spent to load all features. I know, this isn't
a real-world application, but i'm still in test-mode, however it's very good.
With ArcSDE the same layer tooks 40,73 seconds ( ArcIMS ~47 seconds). GREAT!
But with Oracle Spatial, the native support on MapServer 102,1 seconds and
the OGR 119,51!!!
Why?
When I compared the rendering time of a png and a SVG from the same layer
(352.708 byte and 3 features, maybe a real-world problem, isn't it?) I saw a
0,116 seconds for the png and 7,034 for SVG (!), what do I have to do to
speed up the SVG creation?
On "rendering" SVGs, with a query on a QUERY layer like an example found on
ML, from Shapefile, ArcSDE and Oracle Spatial (2,7 Mbyte, 4886 features) the
time was respectively : 3,104 seconds, 19,110 seconds and about 11 minutes
!!! With top I see the CGI resources during an Oracle Spatial query: it
reachs about 700Mbyte of Physical Memory and 2,2 Gbyte of Stack..... what's
happened?
Using ogr2ogr it tooks 3 seconds to create a shapefile from Oracle Spatial
table containing the 260 Mbyte layer! with this I can bypass the problem
converting from Oracle to Shapefile, and using this as the QUERY Layer ( in
example above, this kind of application tooks 3,104 seconds (SVG rendering)
plus the time for conversion (milliseconds?), instead 11 minutes!). But it's
a very poor solution, isn't it?
What do I have to do to solve this performance problem?
Thanks for your help,
Ivano Picco
This is my configuration:
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT 313263.000000 4879724.000000 517049.000000 5145994.000000
UNITS METERS
DEBUG ON
WEB
log "/tmp/CTR_map.log"
IMAGEPATH '/home/mapserver/public_html/tmp/'
IMAGEURL 'http://as2:18091/tmp/'
TEMPLATE 'template.html'
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is the UMN MapServer demonstration application for
Itasca County located in north central Minnesota."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE
"http://localhost.localdomain/mapserver_demos/itasca/demo_init.html"
WMS_SRS "EPSG:32632"
END
HEADER 'header.svg'
FOOTER 'footer.svg'
QUERYFORMAT 'image/svg+xml'
END
LAYER
NAME SVG_SDE
STATUS ON
CONNECTION "gea,port:5151,esri_sde,sde,sde"
CONNECTIONTYPE SDE
DATA "sde.fiumi,SHAPE"
TYPE QUERY
TEMPLATE county.svg
METADATA
WMS_TITLE "Regione SVG"
WMS_ABSTRACT "Esempio per la generazione di SVG"
END
END
LAYER
NAME SVG_SDO
STATUS ON
CONNECTION "OCI:sdo/sdo at GEA"
CONNECTIONTYPE OGR
DATA "SELECT OBJECTID,GEOMETRY FROM fiumi"
TYPE QUERY
TEMPLATE county.svg
METADATA
END
END
LAYER
NAME bound_10k
TYPE POLYGON
DATA shape/bound_10
STATUS ON
CLASS
OUTLINECOLOR 0 0 255
SIZE 4
END
METADATA
WMS_TITLE "County Boundary"
WMS_ABSTRACT "Example og County Boundary"
END
END
END # Map File
My query is:
http://as2:18091/cgi-bin/mapserv?map=/home/mapserver/dati/CTR/CTR.map&mode=itemnquery&qitem=OBJECTID&qstring=/./&qlayer=SVG-SDO
My Application Server (as2):
Red Hat Linux Advanced Server release 2.1AS, kernel 2.4.9-e.3smp, 4 CPUs, 1
Gbyte RAM, 3Gbyte SWAP, Apache 1.3.26, MapServer 4.2.3
