Creating SVG from Shapefile, Oracle Spatial, ArcSDE
Peter Bayley
pbay6343 at BIGPOND.NET.AU
Thu Oct 7 03:29:03 EDT 2004
Have you built spatial indexes for your tables in the Oracle database? I
use PostgreSQL and PostGIS and it's faster than Shape or TAB files
Peter
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, October 06, 2004 10:56 PM
Subject: [UMN_MAPSERVER-USERS] Creating SVG from Shapefile, Oracle Spatial,
ArcSDE
> Hi all,
> I'm a newbie user, I try to find the answer to my problems in the ML
> archives, but i can't find anything for these questions:
> I trying to build a new WebGis application that can be used instead ArcIMS
> based ones to perform a reliable, robust and fast map rendering. I'm
looking
> to MapServer. Since 1 month I spent my time to learn it and test it in
some
> situations, such as rendering png, export WMS map and feature, rendering
SVG
> map.
> In my test I see the best performance achieved by using shapefile, but I
> have to use layer from different sources, also in the same time, like
ArcSDE
> or Oracle Spatial.
> On rendering pngs, my benchmark from a shapefile (260 Mbyte, 198401
> features) hits a 7,62 seconds spent to load all features. I know, this
isn't
> a real-world application, but i'm still in test-mode, however it's very
good.
> With ArcSDE the same layer tooks 40,73 seconds ( ArcIMS ~47 seconds).
GREAT!
> But with Oracle Spatial, the native support on MapServer 102,1 seconds and
> the OGR 119,51!!!
> Why?
> When I compared the rendering time of a png and a SVG from the same layer
> (352.708 byte and 3 features, maybe a real-world problem, isn't it?) I saw
a
> 0,116 seconds for the png and 7,034 for SVG (!), what do I have to do to
> speed up the SVG creation?
> On "rendering" SVGs, with a query on a QUERY layer like an example found
on
> ML, from Shapefile, ArcSDE and Oracle Spatial (2,7 Mbyte, 4886 features)
the
> time was respectively : 3,104 seconds, 19,110 seconds and about 11 minutes
> !!! With top I see the CGI resources during an Oracle Spatial query: it
> reachs about 700Mbyte of Physical Memory and 2,2 Gbyte of Stack.....
what's
> happened?
> Using ogr2ogr it tooks 3 seconds to create a shapefile from Oracle Spatial
> table containing the 260 Mbyte layer! with this I can bypass the problem
> converting from Oracle to Shapefile, and using this as the QUERY Layer (
in
> example above, this kind of application tooks 3,104 seconds (SVG
rendering)
> plus the time for conversion (milliseconds?), instead 11 minutes!). But
it's
> a very poor solution, isn't it?
> What do I have to do to solve this performance problem?
> Thanks for your help,
> Ivano Picco
> This is my configuration:
> NAME DEMO
> STATUS ON
> SIZE 600 600
> EXTENT 313263.000000 4879724.000000 517049.000000 5145994.000000
> UNITS METERS
> DEBUG ON
> WEB
> log "/tmp/CTR_map.log"
> IMAGEPATH '/home/mapserver/public_html/tmp/'
> IMAGEURL 'http://as2:18091/tmp/'
> TEMPLATE 'template.html'
> METADATA
> WMS_TITLE "UMN MapServer Itasca Demo"
> WMS_ABSTRACT "This is the UMN MapServer demonstration application for
> Itasca County located in north central Minnesota."
> WMS_ACCESSCONSTRAINTS none
> # change this value to match your setup
> WMS_ONLINERESOURCE
> "http://localhost.localdomain/mapserver_demos/itasca/demo_init.html"
> WMS_SRS "EPSG:32632"
> END
> HEADER 'header.svg'
> FOOTER 'footer.svg'
> QUERYFORMAT 'image/svg+xml'
> END
> LAYER
> NAME SVG_SDE
> STATUS ON
> CONNECTION "gea,port:5151,esri_sde,sde,sde"
> CONNECTIONTYPE SDE
> DATA "sde.fiumi,SHAPE"
> TYPE QUERY
> TEMPLATE county.svg
> METADATA
> WMS_TITLE "Regione SVG"
> WMS_ABSTRACT "Esempio per la generazione di SVG"
> END
> END
> LAYER
> NAME SVG_SDO
> STATUS ON
> CONNECTION "OCI:sdo/sdo at GEA"
> CONNECTIONTYPE OGR
> DATA "SELECT OBJECTID,GEOMETRY FROM fiumi"
> TYPE QUERY
> TEMPLATE county.svg
> METADATA
> END
> END
> LAYER
> NAME bound_10k
> TYPE POLYGON
> DATA shape/bound_10
> STATUS ON
> CLASS
> OUTLINECOLOR 0 0 255
> SIZE 4
> END
> METADATA
> WMS_TITLE "County Boundary"
> WMS_ABSTRACT "Example og County Boundary"
> END
> END
> END # Map File
> My query is:
http://as2:18091/cgi-bin/mapserv?map=/home/mapserver/dati/CTR/CTR.map&mode=itemnquery&qitem=OBJECTID&qstring=/./&qlayer=SVG-SDO
> My Application Server (as2):
> Red Hat Linux Advanced Server release 2.1AS, kernel 2.4.9-e.3smp, 4 CPUs,
1
> Gbyte RAM, 3Gbyte SWAP, Apache 1.3.26, MapServer 4.2.3
