sdo GTYPE
Javier Castillejo
jcastil1 at TRAGSA.ES
Thu Oct 7 04:49:24 EDT 2004
hI ALL
I'm having problems trying to load data from sph file to SDO oracle
Spatial....
I'm working on a w2k system, IIS 6 and mapserv42(with oracle) and oracle 817
I use shp2sdo, sqlldr ands execute sdomigrate.....
I obtain my shp file from ArcView.
I do the process to loaddata : shp2sdo, load the data, sqlldr and I have no
errors but If I try to execute sde_migrate..._to81x I have an error ...
unable to create the spatial object....
I have a polygon with a hole... and in the sdo i have sdo_gtype= 7
I have another polygon without hole and in the SDA I've sdo_gtype = 3
If I load the data on separates loads I have NO errors but If i mix both I
obtain the error....
I know that the polygon whit a hole should be 3 but instead of that I
obtain 7... Any Idea of:
1.- Why I obtain 7 from a polygon whit a hole
2.- How can I mix polygons with and witout holes
Thanks!
