[geos-devel] GEOS and Mapserver
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Thu Oct 7 14:36:20 EDT 2004
You can do this with mapscript by getting the shape from a layer, build a GeometryFromText() string from the vertices and calling postgis.
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Vladimir Guzmán
Sent: Thursday, October 07, 2004 12:33 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] [geos-devel] GEOS and Mapserver
I've got a question about this:
It could be possible with this library, to make a join in mapserver? What I need is to relate spatial information stored in shapefiles, or in postgis tables, with information stored in Oracle. (I don't want to use Oracle Spatial).
Is this possible?
Thanks a lot,
Vladimir Ilich Guzmán R.
http://maintask.com
Paul Spencer wrote:
> Liz,
> there is a php_ogr library that we built, it is just a set of php
> wrappers for ogr functionality. Frank added GEOS support to OGR
> recently. It should be possible to extend the php_ogr wrappers to
> wrap the ogr functions that talk to GEOS. You could then use OGR to
> open any suitable format, perform GEOS operations like buffer, union,
> etc and then write the results out to a supported format.
> It would also be an interesting exercise to add GEOS support into
> php_mapscript if OGR is built with GEOS support. It should be
> possible to use mapscript shapeObjs with OGR/GEOS and perform suitable
> operations that way.
> The php_ogr stuff is available on www.maptools.org/dl/php_ogr.
> Cheers,
> Paul
> Godwin, Elizabeth wrote:
>> I've cross-posted this to various lists, so I'm sorry to those who
>> are getting duplicates.
>> I'd like to beef up my Mapserver applications with some geoprocessing
>> functionality - buffers at present, other functions will follow. For
>> now I am playing with PostGIS and having great sucess, IF my features
>> are all stored in the database.
>> What I'd like to be able to do though, is take a feature from WMS
>> getFeatureInfo or WFS and be able to buffer that. As a test of this,
>> I took the GML from a getFeatureInfo request and parsed it manually
>> to be a WKT string. Then used PostGIS to run the buffer. Apart from
>> slight precision differences, it appeared to be close to what PostGIS
>> would have done with it's own feature (the WMS request was done
>> against the same feature through MapServer).
>> Now that I confirmed this is all possible, what I am missing is that
>> I'd like to be able to a.. do the conversion from GML to WKT with
>> some script/library b.. do this with a GML stream
>> c.. ultimately do this without PostGIS database dependancy.
>> I figure that GEOS can do the geometry format conversions, is this
>> right? Has anyone written a library for linux/windows that will let
>> me talk to it with PHP?
>> I'm prodding these lists in hopes of finding out what else is going
>> on out there in this area. It would be fabulous if this was all built
>> into Mapserver, but from what I can tell, it's just a thought right
>> now.
>> Thanks!!
>> Liz Godwin
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
> |Paul Spencer pspencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
