Extracting nearest point data with queryByPoint
Thomas Shaw
thomas at REDMILENIO.COM
Thu Oct 7 23:52:31 EDT 2004
Hello!!, I'm actually building an application with mapserver mapscript
php, what I'm trying to do is to get a point from a database (lat, lon)
and use that point to make a query of data in a layer as follows:
map file code:
# Start of map file
MAP
NAME mapa_de_mexico
STATUS ON
SIZE 575 468
SYMBOLSET
/usr/local/mapserver_4/www/trackerweb/modules/Localiza/symbols_mapinfo.sym
#EXTENT -1379278.62 1514480.13 1909424.41 3854862.92
EXTENT -117.53926633136 8.7749367751593 -86.256395549464 34.869751589975
FONTSET "data/fonts/fonts.list" #se definen los nombres cortos de los
tipos de letra
UNITS DD
SHAPEPATH "data/"
IMAGECOLOR 107 181 255
TRANSPARENT off
IMAGETYPE PNG
# Start of web interface definition
WEB
IMAGEPATH "/usr/local/mapserver_4/www/trackerweb/modules/Localiza/tmp/"
IMAGEURL "http://192.168.1.3/trackerweb/modules/Localiza/tmp/"
END
LAYER
NAME puntosMunicipios
GROUP "mex"
TYPE point
STATUS on
CONNECTIONTYPE OGR
CONNECTION "data/mx_pts1.shp"
MAXSCALE 280000
LABELITEM "FULL_NAME"
SYMBOLSCALE 280000
CLASS
COLOR 248 242 135
OUTLINECOLOR 0 0 0
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT georgia
ANTIALIAS TRUE
MINSIZE 8
MAXSIZE 9
END
END # fin de CLASS
CLASS
NAME "puntosMunicipios"
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END
END
php mapscript:
dl('php_mapscript.so');
$map = ms_newMapObj("/usr/local/mapserver_4/www/mexmap.map")
$cond = "select * from lat_lon where grupo='$cve_user' and id_loc='$numloc'";
$res = $db->sql_query ($cond);
$row = $db->sql_fetchrow($res2);
$qx = $row[lon];
$qy = $row[lat];
$point = ms_newpointOBj();
$point->setXY($qx, $qy);
$layer = $map->getLayerByName("puntosMunicipios");
$data = $layer->queryByPoint($point, MS_SINGLE, -1);
$result = $layer->getResult(0);
$layer->open();
$items = $layer->getitems();
$shape =$layer->getShape($result->tileindex, $result->shapeindex);
$layer->close();
$data_val = $shape->values;
foreach($data_val as $data){
echo $data;
and the thing I get is: "Warning: MapServer Error in msQueryByPoint(): No
matching record(s) found. " and the $data variable, contains an array with
all the fields of the dbf-shp, but it only presents the first registry of
the dbf table, and the registry I need is the one that is nearest from the
$point (the one I fetched from lat_lon db). I heard somewhere that I need
a Template to query, but I don't really know how to do it, and also I
think that in mapscript is not necessary isn't it? I thought that it is
only for mapsever cgi. One other thing to consider, is that the "$point",
doesn't exactly matches one coordinate point in the layer
"puntosMunicipios", that's because I used "queryByPoint" to find the
nearest point. Hope that my explanation is enogh clear. I'll appreciate a
lot if anyone can help me with this.
Greetings
Thank you
Thomas Shaw
