Display DOQ at max resolution
Sean Kelly
mapserver at SEAN-KELLY.COM
Sun Oct 10 14:58:11 EDT 2004
Hi all,
I'm working on a setup where the initial display is a WMS layer. (DOQ from
TerraServer.)
With the help of Google and the online examples I have been able to hack
together a setup with php and mapscript where I can display a DOQ from
TerraServer as a raster layer. The image is centered on a given lat/long.
Panning and zooming (out) will be allowed from this starting point. (map
projection is in latlong and map units are in decimal degrees).
My problem is I don't seem to be able to calculate extents from my center
point that allow me to get all the way in to the 1 meter per pixel
resolution that should be available in the TerraServer image. I can get
close, bu I seem to either fall a little short of the desired resolution
or end up too far in and beyond the scale at which MapServer can render
the image. I currently have minscale in the WMS layer set to a very low
level so it will not interfere with my testing.
I guess my questions are:
I'm computing my extents using estimations of lat/long offsets from center
that will get me "in the ball park" for the resolution I want. Have I
missed some facility in mapscript that will calculate extents based upon a
desired center point and scale?
How might I properly calculate the extents based upon a center point such
that I can take advantage of the maximum resolution available from the DOQ
in the raster layer without exceeding the display limits?
Thanks for any help in advance.
Sean
