compilation error ?
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Oct 11 10:05:50 EDT 2004
You might want to point to /usr/local only, i.e. here's my compile:
./configure --with-freetype=/usr/local/bin/freetype-config
--with-zlib=/usr/local --with-png=/usr/local --with-jpeg=/usr/local
--with-xpm=/usr/local --with-g
d=/usr/local --with-pdf=/usr/local --with-eppl --with-proj=/usr/local
--with-gdal=/usr/local/bin/gdal-config
--with-ogr=/usr/local/bin/gdal-config --with-pos
tgis=/usr/local/pgsql/bin/pg_config --with-wfs --with-wcs
--with-wmsclient --with-wfsclient --without-tiff
--with-curl-config=/usr/local/bin/curl-config
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Prashanth Ram
> Sent: Monday, 11 October, 2004 09:16
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] compilation error ?
> I think you need to specify the location of gdal-config.
> ./configure --with-gdal=/usr/local/bin/gdal-config
> -Prashanth
> ----- Original Message -----
> <snip>
> > I tried to compile mapserver nightly built. It failed . However,
> > version 4.2.3 has been built properly with same configuration.
> > ./configure \
> > --with-gdal \
> > --without-tiff \
> > --with-freetype \
> > --with-gd=/usr/local/gd-2.0.28/ \
> --with-proj=/usr/local/proj-4.4.8/ \
> > --with-php=/usr/local/php-5.0.0/
> > developing version gives:
> > configure: error: "Could not find gd.h or libgd.a/libgd.so in
> > /usr/local/gd-2.0.28/. Make sure GD 2.0.12 or higher is compiled
> > before calling configure." ~~~~~~~~~~~
> <snip>
> HTMLX.com
> Mapserver, Mapscript, PHP Hosting
