Hello list, I was playing with the mygis option and it works fine (I tested it with a 15 MB line shapefile). When I query the layer i get a internal server error. Is it possible to use the mygis connector with the query functionality. If not then I will update the WIKI as it says it does support all mapserver functionality. Regards, Wim
