query a mygis layer
Peter Drake
pdrake at GMAIL.COM
Mon Oct 11 11:54:15 EDT 2004
I have the same issue. Attila Csipa (author of mygis) said he would
try to check into it but it has been a couple weeks since then and
I've not heard anything more.
Peter
On Mon, 11 Oct 2004 07:03:23 -0500, Wim Blanken <w.blanken at geon.nl> wrote:
> Hello list,
> I was playing with the mygis option and it works fine (I tested it with a
> 15 MB line shapefile). When I query the layer i get a internal server error.
> Is it possible to use the mygis connector with the query functionality. If
> not then I will update the WIKI as it says it does support all mapserver
> functionality.
> Regards,
> Wim
