About REGEX.
Bob Basques
bob.basques at CI.STPAUL.MN.US
Mon Oct 11 13:09:44 EDT 2004
All,
I have a set of 1 foot contours that I would like to publish.
I had thought about setting up more than one source file for different
resolutions. But, if I can use a REGEX to filter for say 5 and ten foot
elevations (attributes) I can get it all done with a single layer.
Can I filter on the values or characters in some way for display/labelling?
Some desired layers:
All the Contours.
Every 2 feet. (even values)
Every 5 feet. (values ending in "0" or "5")
Every 10 feet. (values ending in "0")
The Elevation value will be an attribute to the (polyline).
Or,
Is it better to build a different dataset for each desired output?
Thanks
bobb
