About REGEX. {Scanned}
Bob Basques
bob.basques at CI.STPAUL.MN.US
Mon Oct 11 18:02:55 EDT 2004
Siki Zoltan wrote:
Thanks, this should work just fine.
Now I need to figure out how to put a Tile index in front of a SHP
file. Supposedly it can be done.
So "$" is the last CHAR. What would I use for the First CHAR? Just put
the $ in the front of the Bracketed stuff?
Thanks Again.
bobb
>>All the Contours.
>>Every 2 feet. (even values)
>EXPRESSION /[02468]$/
>>Every 5 feet. (values ending in "0" or "5")
>EXPRESSION /[05]$/
>>Every 10 feet. (values ending in "0")
>EXPRESSION /0$/
>These regexp will work if you have integer values for the elevation.
>Bye
>Zoltan
