About REGEX. {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Mon Oct 11 20:58:42 EDT 2004
On Mon, 11 Oct 2004, Bob Basques wrote:
> Siki Zoltan wrote:
> Thanks, this should work just fine.
> Now I need to figure out how to put a Tile index in front of a SHP
> file. Supposedly it can be done.
> So "$" is the last CHAR. What would I use for the First CHAR? Just put
> the $ in the front of the Bracketed stuff?
No, use ^ to mask the start
> >>All the Contours.
> >>Every 2 feet. (even values)
> >EXPRESSION /[02468]$/
> >>Every 5 feet. (values ending in "0" or "5")
> >EXPRESSION /[05]$/
> >>Every 10 feet. (values ending in "0")
> >EXPRESSION /0$/
> >These regexp will work if you have integer values for the elevation.
> >Bye
> >Zoltan
