Displaying GRASS]
Jan Hartmann
j.l.h.hartmann at UVA.NL
Thu Oct 14 10:07:44 EDT 2004
Ljiljana wrote:
> Does it work for you? At my server it does not work. I can se only data
> from the location described in .grassrc5 Other locations are not
> recognized as grass data.
> Ljiljana Bodrozic
Well, I tried it out with the following MapFile and it worked:
layer
name a1
status default
type raster
data /grass/refmaps/roads/cellhd/reference
end
layer
name a2
status default
type raster
data /grass/kadaster/plans/cellhd/a3
end
As you see, both rasters are even in different GRASS databases, and they
just show up fine, Are you sure you put the *full* path in your MapFile?
Jan
