Displaying GRASS]
Richard Greenwood
richard.greenwood at GMAIL.COM
Thu Oct 14 12:34:34 EDT 2004
On Thu, 14 Oct 2004 16:07:44 +0200, Jan Hartmann <j.l.h.hartmann at uva.nl> wrote:
> Ljiljana wrote:
> > Does it work for you? At my server it does not work. I can se only data
> > from the location described in .grassrc5 Other locations are not
> > recognized as grass data.
> > Ljiljana Bodrozic
> Well, I tried it out with the following MapFile and it worked:
> layer
> name a1
> status default
> type raster
> data /grass/refmaps/roads/cellhd/reference
> end
> layer
> name a2
> status default
> type raster
> data /grass/kadaster/plans/cellhd/a3
> end
> As you see, both rasters are even in different GRASS databases, and they
> just show up fine, Are you sure you put the *full* path in your MapFile?
> Jan
Jan,
I know you have suggested using the full path in the past, but I never
got it to work. I have always relied upon the .grassrc5 file in
htdocs. I wonder if there is anything else unique to your
configuration that allows the full path approach to work for you, but
not for the rest of us?
Regards,
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
