Contours again.
Bob Basques
bob.basques at CI.STPAUL.MN.US
Fri Oct 15 13:56:30 EDT 2004
Ed McNierney wrote:
>Frank -
>Thanks for chiming in! You're right, of course; Bob made the comment ea=
>rlier:
>"I actually started out with something like that in the AutoCAD world.
>Each tile (1/2 sq. mile) was brought together into a single coverage. I
>didn't do any joins on the linework, I just let them be seperate
>entities. I figured that was better than joining them anyway."
>from which I concluded that these were a lot of small, independent objec=
>ts. But I'm now not sure that's really the case, so, Bob, can you confi=
>rm the arrangement of your data=3F
Yes, the source data was all organized into 1/2 x 1/2 mile tiles (2000 x
2000 ft). When assembled into a single SHP file they were NOT joined
together. They are still polylines though. I'm starting to wonder now
though about exploding them into their respective line segments. The
data size will double though if I do that with all the extra end points
to take manage.
Even though the contours are chopped up by 1/2 mile increments, they are
still quite large polylines, with hundreds of vertices each. I could
chop them up further, down to 500 foot grid tile perhaps. The big
concern for me was labelling. I didn't want to end up with seperate
segments that were labelled to often. I could get away with a single
label per object with the tiling method of aggregation. Seperating
every segment out seems like going backwards for some reason. :c)
I don't recall now if I mentioned this or not, but the contours are at
one foot increments, quite dense and 560+ megs for the *.SHP file. The
qix file was 4+ megs. As a matter of fact, this is the densest dataset
that I need to publish ( so far ) I have the DEM next that was used to
generate the Contours. :c)
bobb
>I ran into a similar situation a few years ago with US street map data, =
>which was originally organized as one shapefile per layer type per state=
>. I was surprised at how noticeable the improvement was when I switched=
> to one shapefile per layer type per COUNTY, as it helped prune large ob=
>jects (interstates, rivers).
> - Ed
>----- Original Message -----
>From: Frank Warmerdam <warmerdam at pobox.com>
>To: Ed McNierney <ed at TOPOZONE.COM>
>Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>Sent: Fri, 15 Oct 2004 12:45:34 -0400
>Subject: Re: [UMN=5FMAPSERVER-USERS] Contours again.
>>Ed McNierney wrote:
>>>Bob -
>>>=20
>>>If things got 25% faster, the index is being used - you don't need t=
>o do
>>anything other than create it. Do you have a feel for what level of b=
>andwidth
>>you're getting from the NAS server=3F Roughly what percentage of the =
>vectors in
>>the shapefile are being used to draw your test image=3F
>>>=20
>>>Don't mess around with different values yet - just use the default. =
> It sounds
>>like you're suffering from either excessively-detailed data (needs
>>simplification for the scales you're using), a test that draws a large
>>percentage of the vectors in the file, and/or poor throughput to the f=
>ile
>>server. A simple test would be to copy the shapefile to the local dis=
>k just to
>>see if there's a difference.
>>=20
>>=20
>>Guys,
>>=20
>>I haven't followed this discussion very closely, so I may have missed
>>something. But one issue I have encountered with contours is that the=
>y
>>often end up being very large polygons. For instance, a "zero elevati=
>on"
>>coastal contour might well be continental sized. Really big "rings" g=
>et
>>pushed way up the the spatial index tree and will have to be read from
>>disk and rendered even if the current map view is just somewhere insid=
>e
>>the contour ring such that the contour won't actually be visible, but
>>the bounding rectangles of the contour and the view area will overlap.
>>=20
>>If this is Bob's problem, he will really be much better off to split t=
>he
>>contours into shortish line segments instead of keeping as massive sin=
>gle
>>geometries as this would allow the spatial index to localize things
>>much better.
>>=20
>>I didn't speak up about this before because it wasn't clear if this ha=
>s
>>already been done.
>>=20
>>Best regards,
>>--=20
>>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at po=
>box.com
>>light and sound - activate the windows | http://pobox.com/~warmerdam
>>and watch the world go round - Rush | Geospatial Programmer for Ren=
>t
>>=20
>>=20
