Contours again.
Ed McNierney
ed at TOPOZONE.COM
Fri Oct 15 14:29:41 EDT 2004
Bob -
Thanks for the info - here are some thoughts:
1. Is there a particular reason you need to merge all those tiles into a single shapefile? Since you're not merging the polylines inside that shapefile, there isn't much benefit (and a bit of harm) in merging them. If you keep each file as a separate tile, you can use a TILEINDEX to combine all the tiles into a single logical layer - as if they were a single shapefile. You can then use shptree on each of those individual tiles to create a spatial index for it. The combination bascially provides a two-level index that can be very efficient.
2. The contour interval has an effect, but so does the granularity of the data. If your source data is at a higher resolution than the output image then you can often end up drawing multiple polyline segments all of which live inside a single output pixel! This is where generalizing the data to a level appropriate to the output can help. If your data has a much higher resolution than the output image, it will simply slow things down - 100 polylines in one pixel looks exactly the same as only 1 polyline in that same pixel. There's no improvement in quality.
3. What is the physical image size (in pixels) and the geographic extent (in feet) of your test image?
- Ed
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Fri, 15 Oct 2004 13:56:30 -0400
Subject: Re: [UMN_MAPSERVER-USERS] Contours again.
> Ed McNierney wrote:
> >Frank -
> >Thanks for chiming in! You're right, of course; Bob made the comment ea=
> >rlier:
> >"I actually started out with something like that in the AutoCAD world.
> >Each tile (1/2 sq. mile) was brought together into a single coverage. I
> >didn't do any joins on the linework, I just let them be seperate
> >entities. I figured that was better than joining them anyway."
> >from which I concluded that these were a lot of small, independent objec=
> >ts. But I'm now not sure that's really the case, so, Bob, can you confi=
> >rm the arrangement of your data=3F
> Yes, the source data was all organized into 1/2 x 1/2 mile tiles (2000 x
> 2000 ft). When assembled into a single SHP file they were NOT joined
> together. They are still polylines though. I'm starting to wonder now
> though about exploding them into their respective line segments. The
> data size will double though if I do that with all the extra end points
> to take manage.
> Even though the contours are chopped up by 1/2 mile increments, they are
> still quite large polylines, with hundreds of vertices each. I could
> chop them up further, down to 500 foot grid tile perhaps. The big
> concern for me was labelling. I didn't want to end up with seperate
> segments that were labelled to often. I could get away with a single
> label per object with the tiling method of aggregation. Seperating
> every segment out seems like going backwards for some reason. :c)
> I don't recall now if I mentioned this or not, but the contours are at
> one foot increments, quite dense and 560+ megs for the *.SHP file. The
> qix file was 4+ megs. As a matter of fact, this is the densest dataset
> that I need to publish ( so far ) I have the DEM next that was used to
> generate the Contours. :c)
> bobb
> >I ran into a similar situation a few years ago with US street map data, =
> >which was originally organized as one shapefile per layer type per state=
> >. I was surprised at how noticeable the improvement was when I switched=
> > to one shapefile per layer type per COUNTY, as it helped prune large ob=
> >jects (interstates, rivers).
> > - Ed
> >From: Frank Warmerdam <warmerdam at pobox.com>
> >To: Ed McNierney <ed at TOPOZONE.COM>
> >Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> >Sent: Fri, 15 Oct 2004 12:45:34 -0400
> >Subject: Re: [UMN=5FMAPSERVER-USERS] Contours again.
> >>Ed McNierney wrote:
> >>>Bob -
> >>>=20
> >>>If things got 25% faster, the index is being used - you don't need t=
> >o do
> >>anything other than create it. Do you have a feel for what level of b=
> >andwidth
> >>you're getting from the NAS server=3F Roughly what percentage of the =
> >vectors in
> >>the shapefile are being used to draw your test image=3F
> >>>=20
> >>>Don't mess around with different values yet - just use the default. =
> > It sounds
> >>like you're suffering from either excessively-detailed data (needs
> >>simplification for the scales you're using), a test that draws a large
> >>percentage of the vectors in the file, and/or poor throughput to the f=
> >ile
> >>server. A simple test would be to copy the shapefile to the local dis=
> >k just to
> >>see if there's a difference.
> >>=20
> >>=20
> >>Guys,
> >>=20
> >>I haven't followed this discussion very closely, so I may have missed
> >>something. But one issue I have encountered with contours is that the=
> >y
> >>often end up being very large polygons. For instance, a "zero elevati=
> >on"
> >>coastal contour might well be continental sized. Really big "rings" g=
> >et
> >>pushed way up the the spatial index tree and will have to be read from
> >>disk and rendered even if the current map view is just somewhere insid=
> >e
> >>the contour ring such that the contour won't actually be visible, but
> >>the bounding rectangles of the contour and the view area will overlap.
> >>=20
> >>If this is Bob's problem, he will really be much better off to split t=
> >he
> >>contours into shortish line segments instead of keeping as massive sin=
> >gle
> >>geometries as this would allow the spatial index to localize things
> >>much better.
> >>=20
> >>I didn't speak up about this before because it wasn't clear if this ha=
> >s
> >>already been done.
> >>=20
> >>Best regards,
> >>--=20
> >>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at po=
> >box.com
> >>light and sound - activate the windows | http://pobox.com/~warmerdam
> >>and watch the world go round - Rush | Geospatial Programmer for Ren=
> >t
> >>=20
> >>=20
