Antw: Re: [UMN_MAPSERVER-USERS] SRID = null; how to to
convert coordinates fr...
Fernando S.
simon at INF.UNIVALI.BR
Fri Oct 15 18:20:25 EDT 2004
Hi Erwin,
Another suggestion.
Can't you define your map unit for meters?
Thank's.
Fernando Simon - simon at inf.univali.br
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada
http://g10.cttmar.univali.br
ErwinVanderBij at cs.com wrote:
>Hello Fernando,
>Your suggestion :
>data "geom from (select
>SDO_CS.TRANSFORM(SDO_CS.VIEWPORT_TRANSFORM(<your geom column>, <SRID for
>millimeters>), <SRID that you want as output>) as geom from <your table>)".
>seems to work!
>Many thanks!
>I did consider this option before, but I thought this would be not possible.
>The documentation of SDO_CS.VIEWPORT_TRANSFORM talks about "optimized
>rectangles" to be used for for this function. So, I thought polygons would not work.
>Kind regards,
>Erwin
