Installation Failure with Proj.dll entry Problem
David Fawcett
David.Fawcett at STATE.MN.US
Tue Oct 19 11:11:23 EDT 2004
You can also use the CONFIG setting in the MAP object to tell mapserver
where to look for your proj file.
http://mapserver.gis.umn.edu/doc42/mapfile-reference.html#map
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> Jacob Delfos <jacob.delfos at MAUNSELL.COM> 10/18/04 11:20 PM >>>
If you want to make sure it is not a problem of the file not being
found, then copy your proj.dll file into
c:\windows\system32
I always copy all DLL's there, because path statements can get a bit
messed up sometimes.
If the problem still occurs, then double-check you have the correct
version of the dll.
Jacob
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Ng Seah Chew
Sent: 18 October 2004 18:20
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Installation Failure with Proj.dll entry
Problem
I am running on Windows 2k3 with Apache 1.3.31.
I have followed the instructions on installing the MapServer 4.2 ReadMe
file.
The MapServer 4.2 is a Win32 binary installer.
I extracted the files to C:/MapServer, moved the "proj" folder to
C:/Proj
and copied the mapserv.exe under "bin" directory to the apache cgi-bin
directory. and set the PATH environment variable to "C:\MapServer\lib"
when run from web browser, I get an Internal Server Error Message, and
if i
double click on the Exe file, i get the following message:
"The procedure entry point pj_units could not be located in the dynamic
link
library PROJ.DLL"
What have i left out during the installation? Please help. Thanks.
