Speeding Up Queries
Eric Katherman
vaiod at BERLOY.COM
Tue Oct 19 17:23:30 EDT 2004
Here is the result of \d (Note I am calling parceldata)
List of relations
Schema | Name | Type | Owner
public | geometry_columns | table | postgres
public | parceldata | table | postgres
public | parceldata_gid_seq | sequence | postgres
public | pga_diagrams | table | postgres
public | pga_forms | table | postgres
public | pga_graphs | table | postgres
public | pga_images | table | postgres
public | pga_layout | table | postgres
public | pga_queries | table | postgres
public | pga_reports | table | postgres
public | pga_scripts | table | postgres
public | spatial_ref_sys | table | postgres
public | streets | table | postgres
public | streets_gid_seq | sequence | postgres
(14 rows)
The call in the mapfile looks like this:
LAYER
GROUP Parcels
NAME parcels
DATA "the_geom from parceldata"
CONNECTION "user=postgres password=guess dbname=gis host=localhost
port=5432"
CONNECTIONTYPE postgis
STATUS On
TYPE POLYGON
PROJECTION
"init=/usr/local/share/proj/nad83:202"
END
CLASS
COLOR 238 230 222
OUTLINECOLOR 172 157 139
END
END
The url contains the extent as well as some other switches I am using to turn
layers on and off. I am using PHP as well. Everything renders as expected
but it seems wastefull to generate the entire map (or at least it seems to)
for a small area.
Eric
> Eric,
> You need to provide more information in your question. Your map file,
> and what URL you are using to hit it, would give some ideas. Plus, if
> you are using PostGIS, the output of \d on the tables you are using.
> Paul
> Eric Katherman wrote:
> > Does anybody have any pointers for speeding up the time MS takes to draw
> > a map based on PostGIS queries? I have shapefiles for all the parcels in
> > my city and when I am zoomed into a smaller area it still seems to
> > calculate everything outside of my extents, can I limit this based on
> > extents somehow maybe?
> > Eric
