Speeding Up Queries
Eric Katherman
vaiod at BERLOY.COM
Tue Oct 19 17:27:10 EDT 2004
Sorry...
Table "public.parceldata"
Column | Type | Modifiers
gid | integer | not null default
nextval('public.parceldata_gid_seq'::text)
area | numeric |
address | character varying |
dbt_end | character varying(8) |
dbt_begin | character varying(8) |
end_date | character varying(8) |
begin_date | character varying(8) |
filename | character varying |
floor | bigint |
apn | character varying |
id | bigint |
the_geom | geometry |
Indexes:
"parceldata_pkey" primary key, btree (gid)
Check constraints:
"enforce_srid_the_geom" CHECK (srid(the_geom) = -1)
"enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL)
> \d parceldata ?
> Eric Katherman wrote:
> > Here is the result of \d (Note I am calling parceldata)
> > List of relations
> > Schema | Name | Type | Owner
> > public | geometry_columns | table | postgres
> > public | parceldata | table | postgres
> > public | parceldata_gid_seq | sequence | postgres
> > public | pga_diagrams | table | postgres
> > public | pga_forms | table | postgres
> > public | pga_graphs | table | postgres
> > public | pga_images | table | postgres
> > public | pga_layout | table | postgres
> > public | pga_queries | table | postgres
> > public | pga_reports | table | postgres
> > public | pga_scripts | table | postgres
> > public | spatial_ref_sys | table | postgres
> > public | streets | table | postgres
> > public | streets_gid_seq | sequence | postgres
> > (14 rows)
> > The call in the mapfile looks like this:
> > LAYER
> > GROUP Parcels
> > NAME parcels
> > DATA "the_geom from parceldata"
> > CONNECTION "user=postgres password=guess dbname=gis host=localhost
> > port=5432"
> > CONNECTIONTYPE postgis
> > STATUS On
> > TYPE POLYGON
> > PROJECTION
> > "init=/usr/local/share/proj/nad83:202"
> > END
> > CLASS
> > COLOR 238 230 222
> > OUTLINECOLOR 172 157 139
> > END
> > END
> > The url contains the extent as well as some other switches I am using to
> > turn layers on and off. I am using PHP as well. Everything renders as
> > expected but it seems wastefull to generate the entire map (or at least
> > it seems to) for a small area.
> > Eric
> >>Eric,
> >>You need to provide more information in your question. Your map file,
> >>and what URL you are using to hit it, would give some ideas. Plus, if
> >>you are using PostGIS, the output of \d on the tables you are using.
> >>Paul
> >>>Does anybody have any pointers for speeding up the time MS takes to draw
> >>>a map based on PostGIS queries? I have shapefiles for all the parcels
> >>> in my city and when I am zoomed into a smaller area it still seems to
> >>> calculate everything outside of my extents, can I limit this based on
> >>> extents somehow maybe?
> >>>Eric
