[UMN_MAPSERVER-USERS] zooming problem continues
temiz
temiz at DEPREM.GOV.TR
Wed Oct 20 04:15:52 EDT 2004
hello again
I am sorry to extend the question.
I think I can get pixel coord of the rectangle drawn with rubberband
(for example $zoom_rect gives [minx] => 171 [miny] => 223 [maxx] => 231
[maxy] => 175).
here is the current extent:
[minx] => 414562.225 [miny] => 4510820 [maxx] => 521317.775 [maxy] =>
4617510
$map->zoomrectangle($zoom_rect,$map->width,$map->height,$my_extent);
this command doesn't bring about any change. I get same image.
I hesitate on:
- $zoom_rect is in image(pixel) coord (or geographic coord).
What might be the problem ?
regards
Skweda O'Bomsawin wrote:
> Temiz,
> You need an onMouseMove event in your image to draw the rectangle and
> have minx != maxx:
> <input type="image" id="mapa" name="mapa"
> src="<?php echo $image_url?>" onMouseDown="startRubber(event)"
> onMouseMove="moveRubber(event) onMouseUp="stopRubber(event)" >
> Skweda O'Bomsawin
> -----Message d'origine-----
> De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> De la part de temiz
> Envoyé : 19 octobre 2004 09:09
> À : MAPSERVER-USERS at LISTS.UMN.EDU
> Objet : [UMN_MAPSERVER-USERS] zooming problem continues
> thank you
> I followed the procedure you offered
> I can draw rubberband. But zooming is not still working.
> I will appreciate if you find what the wrong is ?
> regards
> here is the complete php code:
> <?php
> if (!extension_loaded('php_mapscript.so')) {
> if (!dl('php_mapscript.so')) {
> exit;
> $map_file="./kara.map";
> global $map;
> global $result;
> $map = ms_newMapObj($map_file);
> $jeolayer = $map->getLayerByName("jeo");
> $jeoClass0 = $jeolayer->getClass(9);
> $jeoStyle = $jeoClass0->getStyle("*");
> $jeoStyle->color->setRGB(0,255,0);
> $jeolayer ->set("status",1);
> if ( isset($HTTP_POST_VARS["mapa_x"]) && isset($HTTP_POST_VARS["mapa_y"])
> && !isset($HTTP_POST_VARS["full"]) ) {
> $extent_to_set = explode(" ",$HTTP_POST_VARS["extent"]);
> $map->setextent($extent_to_set[0],$extent_to_set[1],
> $extent_to_set[2],$extent_to_set[3]);
> $my_extent = ms_newrectObj();
> $my_extent->setextent($extent_to_set[0],$extent_to_set[1],
> $zoom_rect = ms_newRectObj();
> $zoom_rect->setextent($_POST["mapa_x"] - $_POST["w"],$_POST["mapa_y"],
> $_POST["mapa_x"],$_POST["mapa_y"]-$_POST["h"]);
> $image=$map->draw();
> $image_url=$image->saveWebImage();
> $extent_to_html = $map->extent->minx." ".$map->extent->miny." "
> .$map->extent->maxx." ".$map->extent->maxy;
> <html>
> <head>
> <title>karabük</title>
> <STYLE>
> #rubberBand {
> position: absolute;
> visibility: hidden;
> width: 0px; height: 0px;
> border: 1px solid #ff0000;
> </STYLE>
> <SCRIPT>
> function startRubber (evt) {
> if (document.all) {
> var r = document.all.rubberBand;
> r.style.width = 0;
> r.style.height = 0;
> r.style.pixelLeft = event.x;
> r.style.pixelTop = event.y;
> r.style.visibility = 'visible';
> else if (document.layers) {
> var r = document.rubberBand;
> r.clip.width = 0; r.clip.height = 0;
> r.left = evt.x;
> r.top = evt.y;
> r.visibility = 'show';
> else if (document.getElementById) {
> var r = document.getElementById('rubberBand');
> r.style.width = 0;
> r.style.height = 0;
> r.style.left = evt.clientX + 'px';
> r.style.top = evt.clientY + 'px';
> document.captureEvents(Event.MOUSEMOVE);
> document.onmousemove = moveRubber;
> function moveRubber (evt) {
> if (document.all) {
> r.style.width = event.x - r.style.pixelLeft - 2;
> r.style.height = event.y - r.style.pixelTop - 2;
> var f = document.forms('viewmap');
> f.w.value = r.style.width;
> f.h.value = r.style.height;
> r.clip.width = evt.x - r.left - 2 ;
> r.clip.height = evt.y - r.top - 2;
> r.document.open();
> r.document.write('<table width="'
> + r.clip.width + '" height="' + r.clip.height
> + '" BORDER="1"><tr><td><\/td><\/tr><\/table>');
> r.document.close();
> f.w.value = r.clip.width;
> f.h.value = r.clip.height;
> r.style.width = evt.clientX - parseInt(r.style.left) - 2;
> r.style.height = evt.clientY - parseInt(r.style.top) - 2;
> var ht = document.getElementById('h');
> var wt = document.getElementById('w');
> wt.value = r.style.width;
> ht.value = r.style.height;
> function stopRubber (evt) {
> document.releaseEvents(Event.MOUSEMOVE);
> document.onmousemove = null;
> </SCRIPT>
> </head>
> <body>
> <CENTER>
> <table cellpadding="1" cellspacing="1" border="1" >
> <FORM name="viewmap" id="viewmap" METHOD=POST ACTION=<?php echo
> $HTTP_SERVER_VARS['PHP_SELF']?>>
> <tr>
> <td colspan="4">zoom</td>
> </tr>
> <tr>
> <td rowspan="3" colspan="2" width="50%">
> <input type="hidden" name="h" id="h" value="0" >
> <input type="hidden" name="w" id="w" value="0" >
> </td>
> <td width="5%"></td>
> <td bgcolor="#ffffcc" > orkun </td>
> </tr>
> <tr>
> <td></td>
> <td bgcolor="#e8e9ea"> ORKUN </td>
> </tr>
> <tr>
> <td>
> </td>
> <td>
> </td>
> </tr>
> <tr>
> <td>coordinat<td>
> <td><td>
> </tr>
> <INPUT TYPE=HIDDEN NAME="extent" VALUE="<?php echo $extent_to_html?>">
> </form>
> <div id="rubberBand" name="rubberBand"></div>
> </table>
> </body>
> </html>
> Sandeep Bashyal wrote:
> On Fri, 15 Oct 2004 10:21:03 +0300, temiz <temiz at deprem.gov.tr>
> <mailto:temiz at deprem.gov.tr> wrote:
> hello Mr.Sandeep,
> thank you for your help.
> I have examined the javascript code you suggested.
> Unfortunately I have also little knowledge about javascript. So, I
> coudn't
> manage to get rectangle coordinates drawn as rubberband.
> I think getting coord. values is the way for zooming.
> Do you have any idea about how coord values can get?
> best wishes
> Bashyal wrote:
> On Thu, 14 Oct 2004 17:13:37 +0300, temiz <temiz at DEPREM.GOV.TR>
> <mailto:temiz at DEPREM.GOV.TR> wrote:
> hello
> for zooming, I want to build rubberband.
> How can I get an example which contain rubberband for zooming ?
> kind regards
> Ahmet temiz
> ______________________________________
> Inflex - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr <mailto:postmaster at deprem.gov.tr>
> The views and opinions expressed in this e-mail message are the sender's
> own
> and do not necessarily represent the views and the opinions of
> Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> nitelikte degildir.
> Ahmet,
> I've found the rubberband zoom box by Gayathri Swaminathan to be simple
> and quite useful. You can download it here:
> http://mapserver.gis.umn.edu/user_utilities/RBand.zip
> Just call startRubber and stopRubber functions on mouseDown and mouseUp
> events on the main map image and put hidden form elements containing the
> width and height of the "rubberband" layer.
> Works pretty well for my limited knowledge of javascript and mapserver
> Regards.
> -- Sandeep Bashyal
> -- National GIS Officer
> Humanitarian Assistance Information System (HAIS)
> United Nations (NEP/01/008)
> UN House, Pulchowk
> G.P.O. Box 107
> Kathmandu, Nepal
> Tel: (+977) 01 5543957
> (+977) 01 5554304
> Cell:(+977) 9841270854
> Fax: (+977) 01 5528059
> mailto:gis at undphais.org.np
> mailto:sandeep at earthmapping.com
> http://www.undp.org.np
> sender's own
> olarak T.C.
> nitelikte degildir.
> Ahmet,
> I'm new to javascript too and could not quite understand how the
> rubberband zoom box works in the included example file. This is how I
> improvised:
> Contents of rubberband.js:
> if (document.all) {
> r.style.width = 0;
> r.style.height = 0;
> r.left = evt.x;
> r.top = evt.y;
> r.style.width = 0;
> r.style.height = 0;
> if (document.all) {
> r.document.open();
> r.document.close();
> Contents of the form:
> <form name="viewmap" id="viewmap" method="post"
> action="<?php echo $HTTP_SERVER_VARS['PHP_SELF'] ?>">
> <input type="hidden" name="h" id="h" value="0" />
> <input type="hidden" name="w" id="w" value="0" />
> onMouseUp="stopRubber(event)" />
> </form>
> Zooming to rectangle (I'm using php mapscript):
> $map->zoomrectangle($zoom_rect,$map->width,$map->height,$current_extent);
> //where $current_extent is a rectangular object with the current
> extent of the map.
> Hope this helps a bit. I've tested it on IE6, NS7, Opera7.5 and
> Firefox0.93.
> Regards.
>The views and opinions expressed in this e-mail message are the sender's own
>and do not necessarily represent the views and the opinions of Earthquake Research Dept.
>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
> Incoming mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.777 / Virus Database: 524 - Release Date: 2004-10-14
> Outgoing mail is certified Virus Free.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041020/35d80f73/attachment.html
