[UMN_MAPSERVER-USERS] zooming problem continues
Skweda O'Bomsawin
sobomsawin at KASSINI.COM
Tue Oct 19 10:28:28 EDT 2004
Temiz,
You need an onMouseMove event in your image to draw the rectangle and have
minx != maxx:
<input type="image" id="mapa" name="mapa"
src="<?php echo $image_url?>" onMouseDown="startRubber(event)"
onMouseMove="moveRubber(event) onMouseUp="stopRubber(event)" >
Skweda O'Bomsawin
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de temiz
Envoyé : 19 octobre 2004 09:09
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] zooming problem continues
thank you
I followed the procedure you offered
I can draw rubberband. But zooming is not still working.
I will appreciate if you find what the wrong is ?
regards
here is the complete php code:
<?php
if (!extension_loaded('php_mapscript.so')) {
if (!dl('php_mapscript.so')) {
exit;
$map_file="./kara.map";
global $map;
global $result;
$map = ms_newMapObj($map_file);
$jeolayer = $map->getLayerByName("jeo");
$jeoClass0 = $jeolayer->getClass(9);
$jeoStyle = $jeoClass0->getStyle("*");
$jeoStyle->color->setRGB(0,255,0);
$jeolayer ->set("status",1);
if ( isset($HTTP_POST_VARS["mapa_x"]) && isset($HTTP_POST_VARS["mapa_y"])
&& !isset($HTTP_POST_VARS["full"]) ) {
$extent_to_set = explode(" ",$HTTP_POST_VARS["extent"]);
$map->setextent($extent_to_set[0],$extent_to_set[1],
$extent_to_set[2],$extent_to_set[3]);
$my_extent = ms_newrectObj();
$my_extent->setextent($extent_to_set[0],$extent_to_set[1],
$zoom_rect = ms_newRectObj();
$zoom_rect->setextent($_POST["mapa_x"] - $_POST["w"],$_POST["mapa_y"],
$_POST["mapa_x"],$_POST["mapa_y"]-$_POST["h"]);
$map->zoomrectangle($zoom_rect,$map->width,$map->height,$my_extent);
$image=$map->draw();
$image_url=$image->saveWebImage();
$extent_to_html = $map->extent->minx." ".$map->extent->miny." "
.$map->extent->maxx." ".$map->extent->maxy;
<html>
<head>
<title>karabük</title>
<STYLE>
#rubberBand {
position: absolute;
visibility: hidden;
width: 0px; height: 0px;
border: 1px solid #ff0000;
</STYLE>
<SCRIPT>
function startRubber (evt) {
if (document.all) {
var r = document.all.rubberBand;
r.style.width = 0;
r.style.height = 0;
r.style.pixelLeft = event.x;
r.style.pixelTop = event.y;
r.style.visibility = 'visible';
else if (document.layers) {
var r = document.rubberBand;
r.clip.width = 0; r.clip.height = 0;
r.left = evt.x;
r.top = evt.y;
r.visibility = 'show';
else if (document.getElementById) {
var r = document.getElementById('rubberBand');
r.style.width = 0;
r.style.height = 0;
r.style.left = evt.clientX + 'px';
r.style.top = evt.clientY + 'px';
document.captureEvents(Event.MOUSEMOVE);
document.onmousemove = moveRubber;
function moveRubber (evt) {
if (document.all) {
r.style.width = event.x - r.style.pixelLeft - 2;
r.style.height = event.y - r.style.pixelTop - 2;
var f = document.forms('viewmap');
f.w.value = r.style.width;
f.h.value = r.style.height;
r.clip.width = evt.x - r.left - 2 ;
r.clip.height = evt.y - r.top - 2;
r.document.open();
r.document.write('<table width="'
+ r.clip.width + '" height="' + r.clip.height
+ '" BORDER="1"><tr><td><\/td><\/tr><\/table>');
r.document.close();
f.w.value = r.clip.width;
f.h.value = r.clip.height;
r.style.width = evt.clientX - parseInt(r.style.left) - 2;
r.style.height = evt.clientY - parseInt(r.style.top) - 2;
var ht = document.getElementById('h');
var wt = document.getElementById('w');
wt.value = r.style.width;
ht.value = r.style.height;
function stopRubber (evt) {
document.releaseEvents(Event.MOUSEMOVE);
document.onmousemove = null;
</SCRIPT>
</head>
<body>
<CENTER>
<table cellpadding="1" cellspacing="1" border="1" >
<FORM name="viewmap" id="viewmap" METHOD=POST ACTION=<?php echo
$HTTP_SERVER_VARS['PHP_SELF']?>>
<tr>
<td colspan="4">zoom</td>
</tr>
<tr>
<td rowspan="3" colspan="2" width="50%">
<input type="hidden" name="h" id="h" value="0" >
<input type="hidden" name="w" id="w" value="0" >
</td>
<td width="5%"></td>
<td bgcolor="#ffffcc" > orkun </td>
</tr>
<tr>
<td></td>
<td bgcolor="#e8e9ea"> ORKUN </td>
</tr>
<tr>
<td>
</td>
<td>
</td>
</tr>
<tr>
<td>coordinat<td>
<td><td>
</tr>
<INPUT TYPE=HIDDEN NAME="extent" VALUE="<?php echo $extent_to_html?>">
</form>
<div id="rubberBand" name="rubberBand"></div>
</table>
</body>
</html>
Sandeep Bashyal wrote:
On Fri, 15 Oct 2004 10:21:03 +0300, temiz <mailto:temiz at deprem.gov.tr>
<temiz at deprem.gov.tr> wrote:
hello Mr.Sandeep,
thank you for your help.
I have examined the javascript code you suggested.
Unfortunately I have also little knowledge about javascript. So, I coudn't
manage to get rectangle coordinates drawn as rubberband.
I think getting coord. values is the way for zooming.
Do you have any idea about how coord values can get?
best wishes
Bashyal wrote:
On Thu, 14 Oct 2004 17:13:37 +0300, temiz <mailto:temiz at DEPREM.GOV.TR>
<temiz at DEPREM.GOV.TR> wrote:
hello
for zooming, I want to build rubberband.
How can I get an example which contain rubberband for zooming ?
kind regards
Ahmet temiz
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's
own
and do not necessarily represent the views and the opinions of
Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
nitelikte degildir.
Ahmet,
I've found the rubberband zoom box by Gayathri Swaminathan to be simple
and quite useful. You can download it here:
http://mapserver.gis.umn.edu/user_utilities/RBand.zip
Just call startRubber and stopRubber functions on mouseDown and mouseUp
events on the main map image and put hidden form elements containing the
width and height of the "rubberband" layer.
Works pretty well for my limited knowledge of javascript and mapserver :).
Regards.
-- Sandeep Bashyal
-- National GIS Officer
Humanitarian Assistance Information System (HAIS)
United Nations (NEP/01/008)
UN House, Pulchowk
G.P.O. Box 107
Kathmandu, Nepal
Tel: (+977) 01 5543957
(+977) 01 5554304
Cell:(+977) 9841270854
Fax: (+977) 01 5528059
mailto:gis at undphais.org.np
mailto:sandeep at earthmapping.com
http://www.undp.org.np
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake
Research Dept.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak
T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte
degildir.
Ahmet,
I'm new to javascript too and could not quite understand how the rubberband
zoom box works in the included example file. This is how I improvised:
Contents of rubberband.js:
if (document.all) {
r.style.width = 0;
r.style.height = 0;
r.left = evt.x;
r.top = evt.y;
r.style.width = 0;
r.style.height = 0;
if (document.all) {
r.document.open();
r.document.close();
Contents of the form:
<form name="viewmap" id="viewmap" method="post"
action="<?php echo $HTTP_SERVER_VARS['PHP_SELF'] ?>">
<input type="hidden" name="h" id="h" value="0" />
<input type="hidden" name="w" id="w" value="0" />
onMouseUp="stopRubber(event)" />
</form>
Zooming to rectangle (I'm using php mapscript):
$map->zoomrectangle($zoom_rect,$map->width,$map->height,$current_extent);
//where $current_extent is a rectangular object with the current extent of
the map.
Hope this helps a bit. I've tested it on IE6, NS7, Opera7.5 and Firefox0.93.
Regards.
Research Dept.
T.C.
degildir.
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.777 / Virus Database: 524 - Release Date: 2004-10-14
Outgoing mail is certified Virus Free.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041019/4aaf7a2b/attachment.html
