zooming problem continues
temiz
temiz at DEPREM.GOV.TR
Tue Oct 19 09:09:25 EDT 2004
thank you
I followed the procedure you offered
I can draw rubberband. But zooming is not still working.
I will appreciate if you find what the wrong is ?
regards
here is the complete php code:
<?php
if (!extension_loaded('php_mapscript.so')) {
if (!dl('php_mapscript.so')) {
exit;
$map_file="./kara.map";
global $map;
global $result;
$map = ms_newMapObj($map_file);
$jeolayer = $map->getLayerByName("jeo");
$jeoClass0 = $jeolayer->getClass(9);
$jeoStyle = $jeoClass0->getStyle("*");
$jeoStyle->color->setRGB(0,255,0);
$jeolayer ->set("status",1);
if ( isset($HTTP_POST_VARS["mapa_x"]) && isset($HTTP_POST_VARS["mapa_y"])
&& !isset($HTTP_POST_VARS["full"]) ) {
$extent_to_set = explode(" ",$HTTP_POST_VARS["extent"]);
$map->setextent($extent_to_set[0],$extent_to_set[1],
$extent_to_set[2],$extent_to_set[3]);
$my_extent = ms_newrectObj();
$my_extent->setextent($extent_to_set[0],$extent_to_set[1],
$zoom_rect = ms_newRectObj();
$zoom_rect->setextent($_POST["mapa_x"] -
$_POST["w"],$_POST["mapa_y"],
$_POST["mapa_x"],$_POST["mapa_y"]-$_POST["h"]);
$map->zoomrectangle($zoom_rect,$map->width,$map->height,$my_extent);
$image=$map->draw();
$image_url=$image->saveWebImage();
$extent_to_html = $map->extent->minx." ".$map->extent->miny." "
.$map->extent->maxx." ".$map->extent->maxy;
<html>
<head>
<title>karabük</title>
<STYLE>
#rubberBand {
position: absolute;
visibility: hidden;
width: 0px; height: 0px;
border: 1px solid #ff0000;
</STYLE>
<SCRIPT>
function startRubber (evt) {
if (document.all) {
var r = document.all.rubberBand;
r.style.width = 0;
r.style.height = 0;
r.style.pixelLeft = event.x;
r.style.pixelTop = event.y;
r.style.visibility = 'visible';
else if (document.layers) {
var r = document.rubberBand;
r.clip.width = 0; r.clip.height = 0;
r.left = evt.x;
r.top = evt.y;
r.visibility = 'show';
else if (document.getElementById) {
var r = document.getElementById('rubberBand');
r.style.width = 0;
r.style.height = 0;
r.style.left = evt.clientX + 'px';
r.style.top = evt.clientY + 'px';
document.captureEvents(Event.MOUSEMOVE);
document.onmousemove = moveRubber;
function moveRubber (evt) {
if (document.all) {
r.style.width = event.x - r.style.pixelLeft - 2;
r.style.height = event.y - r.style.pixelTop - 2;
var f = document.forms('viewmap');
f.w.value = r.style.width;
f.h.value = r.style.height;
r.clip.width = evt.x - r.left - 2 ;
r.clip.height = evt.y - r.top - 2;
r.document.open();
r.document.write('<table width="'
+ r.clip.width + '" height="' + r.clip.height
+ '" BORDER="1"><tr><td><\/td><\/tr><\/table>');
r.document.close();
f.w.value = r.clip.width;
f.h.value = r.clip.height;
r.style.width = evt.clientX - parseInt(r.style.left) - 2;
r.style.height = evt.clientY - parseInt(r.style.top) - 2;
var ht = document.getElementById('h');
var wt = document.getElementById('w');
wt.value = r.style.width;
ht.value = r.style.height;
function stopRubber (evt) {
document.releaseEvents(Event.MOUSEMOVE);
document.onmousemove = null;
</SCRIPT>
</head>
<body>
<CENTER>
<table cellpadding="1" cellspacing="1" border="1" >
<FORM name="viewmap" id="viewmap" METHOD=POST ACTION=<?php echo
$HTTP_SERVER_VARS['PHP_SELF']?>>
<tr>
<td colspan="4">zoom</td>
</tr>
<tr>
<td rowspan="3" colspan="2" width="50%">
<input type="hidden" name="h" id="h" value="0" >
<input type="hidden" name="w" id="w" value="0" >
<input type="image" id="mapa" name="mapa"
src="<?php echo $image_url?>"
onMouseDown="startRubber(event)"
onMouseUp="stopRubber(event)" >
</td>
<td width="5%"></td>
<td bgcolor="#ffffcc" > orkun </td>
</tr>
<tr>
<td></td>
<td bgcolor="#e8e9ea"> ORKUN </td>
</tr>
<tr>
<td>
</td>
<td>
</td>
</tr>
<tr>
<td>coordinat<td>
<td><td>
</tr>
<INPUT TYPE=HIDDEN NAME="extent" VALUE="<?php echo $extent_to_html?>">
</form>
<div id="rubberBand" name="rubberBand"></div>
</table>
</body>
</html>
Sandeep Bashyal wrote:
> On Fri, 15 Oct 2004 10:21:03 +0300, temiz <temiz at deprem.gov.tr> wrote:
>> hello Mr.Sandeep,
>> thank you for your help.
>> I have examined the javascript code you suggested.
>> Unfortunately I have also little knowledge about javascript. So, I
>> coudn't
>> manage to get rectangle coordinates drawn as rubberband.
>> I think getting coord. values is the way for zooming.
>> Do you have any idea about how coord values can get?
>> best wishes
>> Bashyal wrote:
>>> On Thu, 14 Oct 2004 17:13:37 +0300, temiz <temiz at DEPREM.GOV.TR> wrote:
>>>> hello
>>>> for zooming, I want to build rubberband.
>>>> How can I get an example which contain rubberband for zooming ?
>>>> kind regards
>>>> Ahmet temiz
>>>> ______________________________________
>>>> Inflex - installed on mailserver for domain @deprem.gov.tr
>>>> Queries to: postmaster at deprem.gov.tr
>>>> The views and opinions expressed in this e-mail message are the
>>>> sender's
>>>> own
>>>> and do not necessarily represent the views and the opinions of
>>>> Earthquake Research Dept.
>>>> of General Directorate of Disaster Affairs.
>>>> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
>>>> olarak T.C.
>>>> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
>>>> nitelikte degildir.
>>> Ahmet,
>>> I've found the rubberband zoom box by Gayathri Swaminathan to be simple
>>> and quite useful. You can download it here:
>>> http://mapserver.gis.umn.edu/user_utilities/RBand.zip
>>> Just call startRubber and stopRubber functions on mouseDown and mouseUp
>>> events on the main map image and put hidden form elements containing
>>> the
>>> width and height of the "rubberband" layer.
>>> Works pretty well for my limited knowledge of javascript and
>>> mapserver :).
>>> Regards.
>>> -- Sandeep Bashyal
>>> -- National GIS Officer
>>> Humanitarian Assistance Information System (HAIS)
>>> United Nations (NEP/01/008)
>>> UN House, Pulchowk
>>> G.P.O. Box 107
>>> Kathmandu, Nepal
>>> Tel: (+977) 01 5543957
>>> (+977) 01 5554304
>>> Cell:(+977) 9841270854
>>> Fax: (+977) 01 5528059
>>> mailto:gis at undphais.org.np
>>> mailto:sandeep at earthmapping.com
>>> http://www.undp.org.np
>> sender's own
>> olarak T.C.
>> nitelikte degildir.
> Ahmet,
> I'm new to javascript too and could not quite understand how the
> rubberband zoom box works in the included example file. This is how I
> improvised:
> Contents of rubberband.js:
> if (document.all) {
> r.style.width = 0;
> r.style.height = 0;
> r.left = evt.x;
> r.top = evt.y;
> r.style.width = 0;
> r.style.height = 0;
> if (document.all) {
> r.document.open();
> r.document.close();
> Contents of the form:
> <form name="viewmap" id="viewmap" method="post"
> action="<?php echo $HTTP_SERVER_VARS['PHP_SELF'] ?>">
> <input type="hidden" name="h" id="h" value="0" />
> <input type="hidden" name="w" id="w" value="0" />
> src="<?php echo $image_url?>" onMouseDown="startRubber(event)"
> onMouseUp="stopRubber(event)" />
> </form>
> Zooming to rectangle (I'm using php mapscript):
> $zoom_rect->setextent($_POST["mapa_x"] - $_POST["w"],$_POST["mapa_y"],
> $map->zoomrectangle($zoom_rect,$map->width,$map->height,$current_extent);
> //where $current_extent is a rectangular object with the current
> extent of the map.
> Hope this helps a bit. I've tested it on IE6, NS7, Opera7.5 and
> Firefox0.93.
> Regards.
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041019/d9aae188/attachment.html
