query on oraclespatial using OGR/OCI
FERNANDO SIMON
simon at INF.UNIVALI.BR
Thu Oct 21 09:23:00 EDT 2004
Hi Pierre,
I don't use OGR but your problem can be with the spatial index. I saw this
problem with the 10G version.
In the 10G version the Oracle don't recommend use SDO_LEVEL when you create
the spatial index. In my tests problems appears when I set the SDO_LEVEL, the
result doesn't correspond whant I expected.
I don't know if the problem occur with others Oracle Spatial versions. But
you can try with or without SDO_LEVEL.
Fernando Simon - simon at inf.univali.br
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada
http://g10.cttmar.univali.br
Quoting Pierre GIRAUD <bluecarto at FREE.FR>:
> I'm still having difficulties to use mapserver queries on a oracle layer.
> Before I report a bug, I would like someone to test the following SQL
> statement
> and mapfile, and agree that something is going wrong, or tell me I am
> missing
> something obvious.
> Thx
> Pierre GIRAUD
> camptocamp.com
> ---------SQL statement--------------
> DROP table mytable;
> CREATE TABLE MYTABLE (
> GID VARCHAR(20),
> geometry MDSYS.SDO_GEOMETRY);
> insert into MYTABLE (GID,GEOMETRY) values (
> '1',
> mdsys.sdo_geometry(
> '2003',
> null,
> null,
> mdsys.sdo_elem_info_array(1,1003,1),
> mdsys.sdo_ordinate_array(1,1, 1,4, 4,4, 4,1, 1,1))
> '2',
> mdsys.sdo_geometry(
> '2003',
> null,
> null,
> mdsys.sdo_ordinate_array(6,1, 6,4, 9,4, 9,1, 6,1))
> '3',
> mdsys.sdo_geometry(
> '2003',
> null,
> null,
> mdsys.sdo_ordinate_array(1,6, 1,9, 9,9, 9,6, 1,6))
> delete from user_sdo_geom_metadata where table_name like 'MYTABLE';
> insert into user_sdo_geom_metadata (table_name,column_name,diminfo,srid)
> values ('MYTABLE','GEOMETRY',
> mdsys.SDO_DIM_ARRAY(mdsys.SDO_DIM_ELEMENT('X', 0, 10, 0.1),
> mdsys.SDO_DIM_ELEMENT('Y', 0, 10, 0.1)),
> NULL);
> drop index q_mytable;
> create index Q_MYTABLE on MYTABLE(GEOMETRY) indextype is
> MDSYS.spatial_index
> parameters ('SDO_LEVEL=6');
> ---------mapfile---------------
> NAME DEMO
> STATUS ON
> SIZE 500 300
> EXTENT 0 0 10 10
> IMAGECOLOR 255 255 255
> WEB
> IMAGEPATH "/var/www/cartoserver_DGI_flash/www-data/images/"
> IMAGEURL "cartogfx/"
> END
> LAYER
> NAME squares
> TYPE POLYGON
> STATUS ON
> # CONNECTIONTYPE oraclespatial
> # CONNECTION "pierre/xbe9a51h at 192.168.226.149:1521/orcl"
> CONNECTION "OCI:pierre/xbe9a51h at 192.168.226.149:1521/orcl"
> CONNECTIONTYPE OGR
> # DATA "select * from mytable"
> DATA "mytable"
> TEMPLATE "ttt"
> CLASS
> SIZE 10
> COLOR 255 255 255
> OUTLINECOLOR 200 200 200
> END
> END
> END
> Selon bluecarto at free.fr:
> > Hello,
> > Following the good advices of Frank Warmerdam, I improve in using oracle
> > spatial
> > data with spatial indexes. For now, I know that I should not use sql
> > statements
> > in the mapfile but queries directly to the table :
> > DATA "my_table"
> > instead of
> > DATA "select * from my_table"
> > Both return the same images. Shapes are well drawn, and labeling is
> correct.
> > But the first (more performant) statement doesn't give good results to a
> > query.
> > The data returned doesn't correspond to what is expected. And no shape is
> > highlighted.
> > Do someone using Oracle have same problems ?
> > Pierre GIRAUD
> > camptocamp.com
Este e-mail foi enviado pelo webmail do curso de
Ciência da Computação - UNIVALI
