query on oraclespatial using OGR/OCI
Pierre GIRAUD
bluecarto at FREE.FR
Thu Oct 21 06:34:29 EDT 2004
I'm still having difficulties to use mapserver queries on a oracle layer.
Before I report a bug, I would like someone to test the following SQL statement
and mapfile, and agree that something is going wrong, or tell me I am missing
something obvious.
Thx
Pierre GIRAUD
camptocamp.com
---------SQL statement--------------
DROP table mytable;
CREATE TABLE MYTABLE (
GID VARCHAR(20),
geometry MDSYS.SDO_GEOMETRY);
insert into MYTABLE (GID,GEOMETRY) values (
'1',
mdsys.sdo_geometry(
'2003',
null,
null,
mdsys.sdo_elem_info_array(1,1003,1),
mdsys.sdo_ordinate_array(1,1, 1,4, 4,4, 4,1, 1,1))
'2',
mdsys.sdo_geometry(
'2003',
null,
null,
mdsys.sdo_ordinate_array(6,1, 6,4, 9,4, 9,1, 6,1))
'3',
mdsys.sdo_geometry(
'2003',
null,
null,
mdsys.sdo_ordinate_array(1,6, 1,9, 9,9, 9,6, 1,6))
delete from user_sdo_geom_metadata where table_name like 'MYTABLE';
insert into user_sdo_geom_metadata (table_name,column_name,diminfo,srid)
values ('MYTABLE','GEOMETRY',
mdsys.SDO_DIM_ARRAY(mdsys.SDO_DIM_ELEMENT('X', 0, 10, 0.1),
mdsys.SDO_DIM_ELEMENT('Y', 0, 10, 0.1)),
NULL);
drop index q_mytable;
create index Q_MYTABLE on MYTABLE(GEOMETRY) indextype is MDSYS.spatial_index
parameters ('SDO_LEVEL=6');
---------mapfile---------------
NAME DEMO
STATUS ON
SIZE 500 300
EXTENT 0 0 10 10
IMAGECOLOR 255 255 255
WEB
IMAGEPATH "/var/www/cartoserver_DGI_flash/www-data/images/"
IMAGEURL "cartogfx/"
END
LAYER
NAME squares
TYPE POLYGON
STATUS ON
# CONNECTIONTYPE oraclespatial
# CONNECTION "pierre/xbe9a51h at 192.168.226.149:1521/orcl"
CONNECTION "OCI:pierre/xbe9a51h at 192.168.226.149:1521/orcl"
CONNECTIONTYPE OGR
# DATA "select * from mytable"
DATA "mytable"
TEMPLATE "ttt"
CLASS
SIZE 10
COLOR 255 255 255
OUTLINECOLOR 200 200 200
END
END
END
Selon bluecarto at free.fr:
> Hello,
> Following the good advices of Frank Warmerdam, I improve in using oracle
> spatial
> data with spatial indexes. For now, I know that I should not use sql
> statements
> in the mapfile but queries directly to the table :
> DATA "my_table"
> instead of
> DATA "select * from my_table"
> Both return the same images. Shapes are well drawn, and labeling is correct.
> But the first (more performant) statement doesn't give good results to a
> query.
> The data returned doesn't correspond to what is expected. And no shape is
> highlighted.
> Do someone using Oracle have same problems ?
> Pierre GIRAUD
> camptocamp.com
