Arcview view to mapfile extension
Flavio Hendry
flavio at TYDAC.CH
Fri Oct 22 11:14:08 EDT 2004
Hi Manjiri
I'm pretty sure it will not work with ArcViw 9.x. There are however
some talks over here to create such a toll for ArcView 9.x ... won't be
today or tomorrow I suppose ...
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
############ Mit freundlichen Gruessen / Kind Regards
############ mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Date: Fri, 22 Oct 2004 09:50:16 -0500
Subject: Re: [UMN_MAPSERVER-USERS] Arcview view to mapfile extension
> Hello!!
> I'm working on ArcGIS 9, ArcView. I went to the site you suggested
> (http://gix.sourceforge.net/), and downloaded the extention(export
> tool
> version 0.2). And I understand that you said that its meant to export
> ArcGIS 3.x files to .map files, but i just wanted to check if it
> works with
> ArcView 9, but it dosn't seem to work with ArcView 9.
> When I went to ArcMap 9, and tryed to load the extention, it didn't
> give me
> the choice to add "Gix MTS Tools" i.e. I don't see the check box
> for"Gix
> MTS Tools" to select.
> I think this is probably because this export tool is not for ArcView
> 9. And
> if it is supposed to work with ArcView 9, what is the way to load
> this
> extention? Or if you know any other tool like this, that will work
> under
> ArcView 9, please let me know,
> Thank you,
> Manjiri Andhare
> GIS Coordinator
> PA Fish & Boat Commision.
