query on oraclespatial using OGR/OCI
FERNANDO SIMON
simon at INF.UNIVALI.BR
Fri Oct 22 14:57:04 EDT 2004
Hi Javier,
Yes, "the querys" are working correctly now, I tested the query functions
with cgi mode an mapscript functions and both kinds work correctly.
The query support is finished, now I'm working with others supports for the
oraclespatial. So I believe that the querry support will be include in the next
version of mapserver.
Thank's for the help.
Fernando Simon - simon at inf.univali.br
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada
http://g10.cttmar.univali.br
Quoting Javier Castillejo Montes <jcastil1 at TRAGSA.ES>:
> Hi Fernando,
> I understand that you did some work on the mapserver files and now, your
> queries are working?
> As Pierre knows I'm using mapserver with oracle spatial and my next step is
> "The Queries".... If you need any help do not hesitate to told me. I'm
> starting with "The Queries" work, but I will try to help.
> I think that I'm going to use php to generate the queries. It isn't the best
> way, but, for now, Is the only way I know.
> THanks
> -----Mensaje original-----
> De: Fernando S. [mailto:simon at INF.UNIVALI.BR]
> Enviado el: jueves, 21 de octubre de 2004 18:31
> Para: MAPSERVER-USERS at LISTS.UMN.EDU
> Asunto: Re: [UMN_MAPSERVER-USERS] query on oraclespatial using OGR/OCI
> Hi Pierre,
> The query functions can be possible in the next version of the
> Oracle Spatial support. I implemented these functions here in my
> computer and I believe that this functions will be include in the next
> version of native support.
> I don't know how the OGR implement the query function but this
> problem appear when you use functions that use the primary filter like
> SDO_FILTER.
> Here the problem disappear when I recreate the indexes without
> SDO_LEVEL. Another point is the tolerance, you can try set a small
> value for Tolerance like 0.00001.
> bluecarto at free.fr wrote:
> >First question : how can you query oracle layers if you don't use OGR ? I
> mean
> >the function are not implemented for oraclespatial connectiontype.
> >I had already try you suggestion (ommitting the SDO_LEVEL parameter). That
> could
> >be a good idea, but, sadly, it doesn't give any better result.
> >I'm using Oracle 10g on Debian or Oracle 9.2 on RedHat.
> >In my sample the result given seem to be the first record in the table.
> >Regards
> >Pierre
> >Selon FERNANDO SIMON <simon at inf.univali.br>:
> >>Hi Pierre,
> >> I don't use OGR but your problem can be with the spatial index. I saw
> >>this
> >>problem with the 10G version.
> >> In the 10G version the Oracle don't recommend use SDO_LEVEL when you
> >>create
> >>the spatial index. In my tests problems appears when I set the SDO_LEVEL,
> the
> >>result doesn't correspond whant I expected.
> >> I don't know if the problem occur with others Oracle Spatial
> versions.
> >>But
> >>you can try with or without SDO_LEVEL.
> >>Quoting Pierre GIRAUD <bluecarto at FREE.FR>:
> >>> I'm still having difficulties to use mapserver queries on a oracle
> layer.
> >>> Before I report a bug, I would like someone to test the following SQL
> >>>statement
> >>>and mapfile, and agree that something is going wrong, or tell me I am
> >>>missing
> >>>something obvious.
> >>> Thx
> >>> Pierre GIRAUD
> >>> camptocamp.com
> >>>---------SQL statement--------------
> >>>DROP table mytable;
> >>>CREATE TABLE MYTABLE (
> >>> GID VARCHAR(20),
> >>> geometry MDSYS.SDO_GEOMETRY);
> >>>insert into MYTABLE (GID,GEOMETRY) values (
> >>> '1',
> >>> mdsys.sdo_geometry(
> >>> '2003',
> >>> null,
> >>> null,
> >>> mdsys.sdo_elem_info_array(1,1003,1),
> >>> mdsys.sdo_ordinate_array(1,1, 1,4, 4,4, 4,1, 1,1))
> >>> '2',
> >>> mdsys.sdo_geometry(
> >>> '2003',
> >>> null,
> >>> null,
> >>> mdsys.sdo_ordinate_array(6,1, 6,4, 9,4, 9,1, 6,1))
> >>> '3',
> >>> mdsys.sdo_geometry(
> >>> '2003',
> >>> null,
> >>> null,
> >>> mdsys.sdo_ordinate_array(1,6, 1,9, 9,9, 9,6, 1,6))
> >>>delete from user_sdo_geom_metadata where table_name like 'MYTABLE';
> >>>insert into user_sdo_geom_metadata (table_name,column_name,diminfo,srid)
> >>>values ('MYTABLE','GEOMETRY',
> >>>mdsys.SDO_DIM_ARRAY(mdsys.SDO_DIM_ELEMENT('X', 0, 10, 0.1),
> >>>mdsys.SDO_DIM_ELEMENT('Y', 0, 10, 0.1)),
> >>>NULL);
> >>>drop index q_mytable;
> >>>create index Q_MYTABLE on MYTABLE(GEOMETRY) indextype is
> >>>MDSYS.spatial_index
> >>>parameters ('SDO_LEVEL=6');
> >>>---------mapfile---------------
> >>>NAME DEMO
> >>>STATUS ON
> >>>SIZE 500 300
> >>>EXTENT 0 0 10 10
> >>>IMAGECOLOR 255 255 255
> >>>WEB
> >>> IMAGEPATH "/var/www/images/"
> >>> IMAGEURL "images/"
> >>>END
> >>>LAYER
> >>> NAME squares
> >>> TYPE POLYGON
> >>> STATUS ON
> >>># CONNECTIONTYPE oraclespatial
> >>># CONNECTION "scott/tiger at orcl"
> >>> CONNECTION "OCI:scott/tiger at orcl"
> >>> CONNECTIONTYPE OGR
> >>># DATA "select * from mytable"
> >>> DATA "mytable"
> >>> TEMPLATE "ttt"
> >>> CLASS
> >>> SIZE 10
> >>> COLOR 255 255 255
> >>> OUTLINECOLOR 200 200 200
> >>> END
> >>>END
> >>>END
> >>>Selon bluecarto at free.fr:
> >>>> Hello,
> >>>>Following the good advices of Frank Warmerdam, I improve in using
> oracle
> >>>>spatial
> >>>>data with spatial indexes. For now, I know that I should not use sql
> >>>>statements
> >>>>in the mapfile but queries directly to the table :
> >>>> DATA "my_table"
> >>>>instead of
> >>>> DATA "select * from my_table"
> >>>>Both return the same images. Shapes are well drawn, and labeling is
> >>>correct.
> >>>>But the first (more performant) statement doesn't give good results to
> a
> >>>>query.
> >>>>The data returned doesn't correspond to what is expected. And no shape
> is
> >>>>highlighted.
> >>>>Do someone using Oracle have same problems ?
> >>>>Pierre GIRAUD
> >>>>camptocamp.com
> >>Este e-mail foi enviado pelo webmail do curso de
> >> Ciência da Computação - UNIVALI
