query on oraclespatial using OGR/OCI
Pierre GIRAUD
bluecarto at FREE.FR
Fri Oct 29 03:29:30 EDT 2004
Do you have any idea when it will be included in a version of Mapserver ?
Pierre GIRAUD
Selon FERNANDO SIMON <simon at INF.UNIVALI.BR>:
> Hi Javier,
> Yes, "the querys" are working correctly now, I tested the query functions
> with cgi mode an mapscript functions and both kinds work correctly.
> The query support is finished, now I'm working with others supports for
> the
> oraclespatial. So I believe that the querry support will be include in the
> next
> version of mapserver.
> Thank's for the help.
> Fernando Simon - simon at inf.univali.br
> Mapserver and Oracle Spatial developer
> G10 - Laboratorio de Computacao Aplicada
> http://g10.cttmar.univali.br
> Quoting Javier Castillejo Montes <jcastil1 at TRAGSA.ES>:
> > Hi Fernando,
> > I understand that you did some work on the mapserver files and now, your
> > queries are working?
> > As Pierre knows I'm using mapserver with oracle spatial and my next step is
> > "The Queries".... If you need any help do not hesitate to told me. I'm
> > starting with "The Queries" work, but I will try to help.
> > I think that I'm going to use php to generate the queries. It isn't the
> best
> > way, but, for now, Is the only way I know.
> > THanks
> > -----Mensaje original-----
> > De: Fernando S. [mailto:simon at INF.UNIVALI.BR]
> > Enviado el: jueves, 21 de octubre de 2004 18:31
> > Para: MAPSERVER-USERS at LISTS.UMN.EDU
> > Asunto: Re: [UMN_MAPSERVER-USERS] query on oraclespatial using OGR/OCI
> > Hi Pierre,
> > The query functions can be possible in the next version of the
> > Oracle Spatial support. I implemented these functions here in my
> > computer and I believe that this functions will be include in the next
> > version of native support.
> > I don't know how the OGR implement the query function but this
> > problem appear when you use functions that use the primary filter like
> > SDO_FILTER.
> > Here the problem disappear when I recreate the indexes without
> > SDO_LEVEL. Another point is the tolerance, you can try set a small
> > value for Tolerance like 0.00001.
> > bluecarto at free.fr wrote:
> > >First question : how can you query oracle layers if you don't use OGR ? I
> > mean
> > >the function are not implemented for oraclespatial connectiontype.
> > >I had already try you suggestion (ommitting the SDO_LEVEL parameter). That
> > could
> > >be a good idea, but, sadly, it doesn't give any better result.
> > >I'm using Oracle 10g on Debian or Oracle 9.2 on RedHat.
> > >In my sample the result given seem to be the first record in the table.
> > >Regards
> > >Pierre
> > >Selon FERNANDO SIMON <simon at inf.univali.br>:
> > >>Hi Pierre,
> > >> I don't use OGR but your problem can be with the spatial index. I saw
> > >>this
> > >>problem with the 10G version.
> > >> In the 10G version the Oracle don't recommend use SDO_LEVEL when you
> > >>create
> > >>the spatial index. In my tests problems appears when I set the SDO_LEVEL,
> > the
> > >>result doesn't correspond whant I expected.
> > >> I don't know if the problem occur with others Oracle Spatial
> > versions.
> > >>But
> > >>you can try with or without SDO_LEVEL.
> > >>Quoting Pierre GIRAUD <bluecarto at FREE.FR>:
> > >>> I'm still having difficulties to use mapserver queries on a oracle
> > layer.
> > >>> Before I report a bug, I would like someone to test the following SQL
> > >>>statement
> > >>>and mapfile, and agree that something is going wrong, or tell me I am
> > >>>missing
> > >>>something obvious.
> > >>> Thx
> > >>> Pierre GIRAUD
> > >>> camptocamp.com
> > >>>---------SQL statement--------------
> > >>>DROP table mytable;
> > >>>CREATE TABLE MYTABLE (
> > >>> GID VARCHAR(20),
> > >>> geometry MDSYS.SDO_GEOMETRY);
> > >>>insert into MYTABLE (GID,GEOMETRY) values (
> > >>> '1',
> > >>> mdsys.sdo_geometry(
> > >>> '2003',
> > >>> null,
> > >>> null,
> > >>> mdsys.sdo_elem_info_array(1,1003,1),
> > >>> mdsys.sdo_ordinate_array(1,1, 1,4, 4,4, 4,1, 1,1))
> > >>> '2',
> > >>> mdsys.sdo_geometry(
> > >>> '2003',
> > >>> null,
> > >>> null,
> > >>> mdsys.sdo_ordinate_array(6,1, 6,4, 9,4, 9,1, 6,1))
> > >>> '3',
> > >>> mdsys.sdo_geometry(
> > >>> '2003',
> > >>> null,
> > >>> null,
> > >>> mdsys.sdo_ordinate_array(1,6, 1,9, 9,9, 9,6, 1,6))
> > >>>delete from user_sdo_geom_metadata where table_name like 'MYTABLE';
> > >>>insert into user_sdo_geom_metadata (table_name,column_name,diminfo,srid)
> > >>>values ('MYTABLE','GEOMETRY',
> > >>>mdsys.SDO_DIM_ARRAY(mdsys.SDO_DIM_ELEMENT('X', 0, 10, 0.1),
> > >>>mdsys.SDO_DIM_ELEMENT('Y', 0, 10, 0.1)),
> > >>>NULL);
> > >>>drop index q_mytable;
> > >>>create index Q_MYTABLE on MYTABLE(GEOMETRY) indextype is
> > >>>MDSYS.spatial_index
> > >>>parameters ('SDO_LEVEL=6');
> > >>>---------mapfile---------------
> > >>>NAME DEMO
> > >>>STATUS ON
> > >>>SIZE 500 300
> > >>>EXTENT 0 0 10 10
> > >>>IMAGECOLOR 255 255 255
> > >>>WEB
> > >>> IMAGEPATH "/var/www/images/"
> > >>> IMAGEURL "images/"
> > >>>END
> > >>>LAYER
> > >>> NAME squares
> > >>> TYPE POLYGON
> > >>> STATUS ON
> > >>># CONNECTIONTYPE oraclespatial
> > >>># CONNECTION "scott/tiger at orcl"
> > >>> CONNECTION "OCI:scott/tiger at orcl"
> > >>> CONNECTIONTYPE OGR
> > >>># DATA "select * from mytable"
> > >>> DATA "mytable"
> > >>> TEMPLATE "ttt"
> > >>> CLASS
> > >>> SIZE 10
> > >>> COLOR 255 255 255
> > >>> OUTLINECOLOR 200 200 200
> > >>> END
> > >>>END
> > >>>END
> > >>>Selon bluecarto at free.fr:
> > >>>> Hello,
> > >>>>Following the good advices of Frank Warmerdam, I improve in using
> > oracle
> > >>>>spatial
> > >>>>data with spatial indexes. For now, I know that I should not use sql
> > >>>>statements
> > >>>>in the mapfile but queries directly to the table :
> > >>>> DATA "my_table"
> > >>>>instead of
> > >>>> DATA "select * from my_table"
> > >>>>Both return the same images. Shapes are well drawn, and labeling is
> > >>>correct.
> > >>>>But the first (more performant) statement doesn't give good results to
> > a
> > >>>>query.
> > >>>>The data returned doesn't correspond to what is expected. And no shape
> > is
> > >>>>highlighted.
> > >>>>Do someone using Oracle have same problems ?
> > >>>>Pierre GIRAUD
> > >>>>camptocamp.com
> > >>Este e-mail foi enviado pelo webmail do curso de
> > >> Ciência da Computação - UNIVALI
