multiple join {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Sun Oct 24 16:20:49 EDT 2004
Hi List,
I try to use multiple join between a shape file and a dbf.
I was able to join one-to-one (single), but after changing it to
multiple join, no errors, no result.
part of my map file
# parcels
LAYER
NAME "kafold"
DATA "alapterkep/kafold.shp"
STATUS ON
GROUP "telkek"
TYPE POLYGON
CLASS
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
TEMPLATE "telek_cim.html"
END
HEADER "telek_cim_header.html"
FOOTER "telek_cim_footer.html"
JOIN
NAME cim
TABLE "cimek/ujcimek1.shp"
FROM HRSZ
TO HRSZ
TYPE multiple
TEMPLATE "cim_template.html"
END
END
and the template for join
<p>
Address: [cim_CIM]<br>
</p>
No part of the template for multiple join displayed.
If I remove the TYPE and TEMPLATE rows from the map file it works, of
course I add the cim_CIM column to the other template.
MapServer version 4.2.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I've tried with 4.0, the result is the same.
Any suggestion?
Thanx
Zoltan
