multiple join {Scanned}
Richard Greenwood
richard.greenwood at GMAIL.COM
Sun Oct 24 17:20:47 EDT 2004
On Sun, 24 Oct 2004 19:20:49 -0100, Siki Zoltan <siki at agt.bme.hu> wrote:
> Hi List,
> I try to use multiple join between a shape file and a dbf.
> I was able to join one-to-one (single), but after changing it to
> multiple join, no errors, no result.
> part of my map file
> # parcels
> LAYER
> NAME "kafold"
> DATA "alapterkep/kafold.shp"
> STATUS ON
> GROUP "telkek"
> TYPE POLYGON
> CLASS
> COLOR -1 -1 -1
> OUTLINECOLOR 0 0 0
> TEMPLATE "telek_cim.html"
> END
> HEADER "telek_cim_header.html"
> FOOTER "telek_cim_footer.html"
> JOIN
> NAME cim
> TABLE "cimek/ujcimek1.shp"
> FROM HRSZ
> TO HRSZ
> TYPE multiple
> TEMPLATE "cim_template.html"
> END
> END
> and the template for join
> <p>
> Address: [cim_CIM]<br>
> </p>
> No part of the template for multiple join displayed.
> If I remove the TYPE and TEMPLATE rows from the map file it works, of
> course I add the cim_CIM column to the other template.
> MapServer version 4.2.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I've tried with 4.0, the result is the same.
> Any suggestion?
> Thanx
> Zoltan
Try:
TYPE one-to-many
instead of "multiple"
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
