multiple join {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Tue Oct 26 15:28:19 EDT 2004
On Sun, 24 Oct 2004, Richard Greenwood wrote:
> On Sun, 24 Oct 2004 19:20:49 -0100, Siki Zoltan <siki at agt.bme.hu> wrote:
> > Hi List,
> > I try to use multiple join between a shape file and a dbf.
> > I was able to join one-to-one (single), but after changing it to
> > multiple join, no errors, no result.
> > part of my map file
> > # parcels
> > LAYER
> > NAME "kafold"
> > DATA "alapterkep/kafold.shp"
> > STATUS ON
> > GROUP "telkek"
> > TYPE POLYGON
> > CLASS
> > COLOR -1 -1 -1
> > OUTLINECOLOR 0 0 0
> > TEMPLATE "telek_cim.html"
> > END
> > HEADER "telek_cim_header.html"
> > FOOTER "telek_cim_footer.html"
> > JOIN
> > NAME cim
> > TABLE "cimek/ujcimek1.shp"
> > FROM HRSZ
> > TO HRSZ
> > TYPE multiple
> > TEMPLATE "cim_template.html"
> > END
> > END
> > and the template for join
> > <p>
> > Address: [cim_CIM]<br>
> > </p>
> > No part of the template for multiple join displayed.
> > If I remove the TYPE and TEMPLATE rows from the map file it works, of
> > course I add the cim_CIM column to the other template.
> > MapServer version 4.2.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> > SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER INPUT=EPPL7
> > INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > I've tried with 4.0, the result is the same.
> > Any suggestion?
> > Thanx
> > Zoltan
> Try:
> TYPE one-to-many
> instead of "multiple"
It doesn't help.
Where should the join template inserted to? Before FOOTER, after Header?
Any other idea?
Thanx
Zoltan
