multiple join {Scanned}
Richard Greenwood
richard.greenwood at GMAIL.COM
Tue Oct 26 21:47:01 EDT 2004
On Tue, 26 Oct 2004 18:28:19 -0100 (GMT+1), Siki Zoltan <siki at agt.bme.hu> wrote:
> On Sun, 24 Oct 2004, Richard Greenwood wrote:
> > On Sun, 24 Oct 2004 19:20:49 -0100, Siki Zoltan <siki at agt.bme.hu> wrote:
> > > Hi List,
> > > I try to use multiple join between a shape file and a dbf.
> > > I was able to join one-to-one (single), but after changing it to
> > > multiple join, no errors, no result.
> > > part of my map file
> > > # parcels
> > > LAYER
> > > NAME "kafold"
> > > DATA "alapterkep/kafold.shp"
> > > STATUS ON
> > > GROUP "telkek"
> > > TYPE POLYGON
> > > CLASS
> > > COLOR -1 -1 -1
> > > OUTLINECOLOR 0 0 0
> > > TEMPLATE "telek_cim.html"
> > > END
> > > HEADER "telek_cim_header.html"
> > > FOOTER "telek_cim_footer.html"
> > > JOIN
> > > NAME cim
> > > TABLE "cimek/ujcimek1.shp"
> > > FROM HRSZ
> > > TO HRSZ
> > > TYPE multiple
> > > TEMPLATE "cim_template.html"
> > > END
> > > END
> > > and the template for join
> > > <p>
> > > Address: [cim_CIM]<br>
> > > </p>
> > > No part of the template for multiple join displayed.
> > > If I remove the TYPE and TEMPLATE rows from the map file it works, of
> > > course I add the cim_CIM column to the other template.
> > > MapServer version 4.2.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> > > SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER INPUT=EPPL7
> > > INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > > I've tried with 4.0, the result is the same.
> > > Any suggestion?
> > > Thanx
> > > Zoltan
> > Try:
> > TYPE one-to-many
> > instead of "multiple"
> It doesn't help.
> Where should the join template inserted to? Before FOOTER, after Header?
> Any other idea?
> Thanx
> Zoltan
Your JOIN definition looks good to me. I do not think it matters
before or after HEADER or FOOTER. I think you should try a full path
to the TABLE. You have:
But try a fully qualified path like:
/var/www/mystuff /cimek/ujcimek1.shp
Regards,
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
