Timestamped Map
Brent Fraser
bfraser at GEOANALYTIC.COM
Mon Oct 25 10:45:43 EDT 2004
Charlie,
I'm not sure if this is the best way but we did something similar a couple
of years ago using the following layer definition:
LAYER
NAME "TimeStamp"
TYPE ANNOTATION
STATUS DEFAULT
TRANSFORM FALSE
FEATURE
POINTS 20 20 END # Text in Upper-left
TEXT "Terra MODIS [imagedate] [imagetime] UT"
END
CLASS
LABEL
COLOR 255 255 255
OUTLINECOLOR 0 0 0
TYPE TRUETYPE
FONT comic
SIZE 16
POSITION AUTO
FORCE TRUE
OFFSET 10 10
PARTIALS FALSE
WRAP ","
END # Label
END # CLASS
END
In our case we pre-processed the map file to substitute the "[imagedate]
[imagetime]" with the date the data was aquired (not the date the map
graphic was generated) by using some purpose-built software on the server.
I think you would be able to use a CGI variable to change the text, but I
haven't tried it. I think the CGI syntax would be something like:
...&map_TimeStamp_feature_text=Terra+Modis+20041025&...
and you'll likely need URL encoding for characters other than alphanumerics.
Brent Fraser
GeoAnalytic Inc.
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, October 25, 2004 7:38 AM
Subject: [UMN_MAPSERVER-USERS] Timestamped Map
Greetings,
Id like to place a timestamp on each map that is created.
What is the bext way to do this? Im using mapserver cgi version 4.2 and
Id prefer to not change this configuration. If possible Id like to do so
using the map file or dhtml.
TIA
Charlie
