Timestamped Map
IMD Listuser
imd_listuser at COMCAST.NET
Mon Oct 25 11:44:44 EDT 2004
Hi
Thanks for the reply.
Unfortunately when I try to duplicate your code, the only thing that
appears on the map is "Terra MODIS [imagedate] [imagetime] UT". Even if
I substitute a known cgi variable like [mapext], it does not get
evaluated prior to being drawn on the map.
Hmmm. Any Ideas
Charlie
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Brent Fraser
Sent: Monday, October 25, 2004 10:46
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Timestamped Map
Charlie,
I'm not sure if this is the best way but we did something similar a
couple of years ago using the following layer definition:
LAYER
NAME "TimeStamp"
TYPE ANNOTATION
STATUS DEFAULT
TRANSFORM FALSE
FEATURE
POINTS 20 20 END # Text in Upper-left
TEXT "Terra MODIS [imagedate] [imagetime] UT"
END
CLASS
LABEL
COLOR 255 255 255
OUTLINECOLOR 0 0 0
TYPE TRUETYPE
FONT comic
SIZE 16
POSITION AUTO
FORCE TRUE
OFFSET 10 10
PARTIALS FALSE
WRAP ","
END # Label
END # CLASS
END
In our case we pre-processed the map file to substitute the "[imagedate]
[imagetime]" with the date the data was aquired (not the date the map
graphic was generated) by using some purpose-built software on the
server.
I think you would be able to use a CGI variable to change the text, but
I haven't tried it. I think the CGI syntax would be something like:
...&map_TimeStamp_feature_text=Terra+Modis+20041025&...
and you'll likely need URL encoding for characters other than
alphanumerics.
Brent Fraser
GeoAnalytic Inc.
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, October 25, 2004 7:38 AM
Subject: [UMN_MAPSERVER-USERS] Timestamped Map
Greetings,
Id like to place a timestamp on each map that is created.
What is the bext way to do this? Im using mapserver cgi version 4.2 and
Id prefer to not change this configuration. If possible Id like to do so
using the map file or dhtml.
TIA
Charlie
