More GD errors
Norman Barker
normanb at COMSINE.CO.UK
Mon Oct 25 12:54:51 EDT 2004
Sean Gillies wrote:
> On Oct 25, 2004, at 9:18 AM, Norman Barker wrote:
>> Hi,
>> I have switched boxes to a clean install of Red Hat FC2 to compile
>> MapServer (nightly build),
>> FC2 ships with the 2 series version of GD as required mapserver but the
>> configure script still fails
>> to pick it up even when I use --with-gd=/usr/local
>> Has anyone got a (fool-proof!) set of instructions for compiling
>> MapServer? This GD error
>> is a hurdle I can't get over!
>> Many thanks,
>> Norman Barker
> Norman,
> If you provide more details, I'll try to help. Your message gives us
> little to
> go on. Specifically: MapServer version, the output of the configure
> script,
> and your actual configure command.
> I'm using a FC2-based distribution (KRUD) and it comes with GD 1.8.4 in
> /usr/lib.
> Are you sure you have a GD 2? If so, where are the libraries and
> include files
> found?
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
I have to boxes one that is running Red Hat 9 and the other FC 2, the
errors are the same so I will describe both
I building the nightly snapshot of MapServer so that I can use the WCS
functionality.
I have a version of GD in /usr/lib, and version 2.x of GD in usr/local/lib
so running
./configure --with-wcs --with-gd=/usr/local --with-proj=/usr/bin
--with-png=/usr/lib --with-wmsclient --with-curl-config=/usr/bin/curl-config --with-wfsc
lient --with-ogr=/usr/bin/gdal-config --with-gdal=/usr/bin/gdal-config --with-wfs
(as kindly given by Newland Agbenowosi)
gives the following error
"Could not find gd.h or libgd.a/libgd.so in /usr/local. Make sure GD
2.0.12 or higher is compiled before calling configure."
Any help would be greatly appreciated.
Norman
