center point using data from PostGIS
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Mon Oct 25 14:52:10 EDT 2004
Use the DB.php interface and make a query to postgis.
The postgis function centroid ought to do what you want.
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Yannick Doiron
Sent: Monday, October 25, 2004 12:03 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] center point using data from PostGIS
Hi list,
I am using MapServer CGI 4.2 on window XP with PostGIS data connect to it.
I'a using the code below to center the map on a point choosed by the user from a select list.
<select name="ViewEmploye" id=emp onchange="employe();" size="1"> <option value="-1">Employes</option> <option value="-1">-------------</option> <option value="359877 5276306"> Annelle Duguay </option> <option value="336655 5297926"> Thérèse Haché </option> <option value="357748 5295074"> Yannick Doiron </option> </select>
I want to be able to get the coordinate from a PostGIS database instead of writing it like the code above. I was able to import my data in PostGIS and see it with MapServer. I know I will have to use PHPMapscript. I have it install and working (I have the ms4w package from maptools.org installed) but I am not very good php programming.
Can somone lead me at a tutorial or else on how to achieve this? If this was asked and answered in the past, please forward me the link.
Thanks in advance,
Yannick
