[UMN_MAPSERVER-USERS] center point using data from PostGIS
Skweda O'Bomsawin
sobomsawin at KASSINI.COM
Mon Oct 25 14:51:22 EDT 2004
You can take a look at the PostGIS user manual:
http://postgis.refractions.net/docs/
Look at the extent option from sql, something like that:
select xmin(extent(wkb_geometry)),
ymin(extent(wkb_geometry)),xmax(extent(wkb_geometry)),ymax(extent(wkb_geomet
ry)) from employes where emp='Annele Duguay';
Dans l'espoir de vous mettre sur la bonne voie!
Skweda O'Bomsawin
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Yannick Doiron
Envoyé : 25 octobre 2004 14:03
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] center point using data from PostGIS
Hi list,
I am using MapServer CGI 4.2 on window XP with PostGIS data connect to it.
I'a using the code below to center the map on a point choosed by the user
from a select list.
<select name="ViewEmploye" id=emp onchange="employe();" size="1">
<option value="-1">Employes</option>
<option value="-1">-------------</option>
<option value="359877 5276306"> Annelle Duguay </option>
<option value="336655 5297926"> Thérèse Haché </option>
<option value="357748 5295074"> Yannick Doiron </option>
</select>
I want to be able to get the coordinate from a PostGIS database instead of
writing it like the code above. I was able to import my data in PostGIS and
see it with MapServer. I know I will have to use PHPMapscript. I have it
install and working (I have the ms4w package from maptools.org installed)
but I am not very good php programming.
Can somone lead me at a tutorial or else on how to achieve this? If this
was asked and answered in the past, please forward me the link.
Thanks in advance,
Yannick
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.779 / Virus Database: 526 - Release Date: 2004-10-19
Outgoing mail is certified Virus Free.
